> Stuff I should do between races
Page 2 of 2
28-Apr-2013, 13:43
Ghost
: Ducati 749, Phil Read Replica, DD 620
: 2011 DD Class 'B' Champion
The strainer is under the plug that is beneath the clutch cover. When that plug has been removed and the oil let loose, you will need a 14mm Allen key to extract the strainer. Its a tubular fine gauze in nylon and about 120mm long and 22mm diameter.
Ghost
Send a personal message to Ghost
Find all posts by Ghost
12
28-Apr-2013, 13:52
chris.p
: Monster 1100 EVO
: I'm A Grandad again :-)
I think the one on Jim's is attached to the bolt head so it's a one piece not two piece version.
chris.p
Send a personal message to chris.p
Find all posts by chris.p
13
28-Apr-2013, 22:22
Bimjob
: Yamaha R1, Ducati 600SS
Thanks I didn't know about that. So this strainer should be replaced at the same time as the oil and filter?
Bimjob
Send a personal message to Bimjob
Send email to Bimjob
Visit Bimjob's homepage!
Find all posts by Bimjob
14
28-Apr-2013, 22:58
chris.p
: Monster 1100 EVO
Originally Posted by
Bimjob
No, it just needs removing and cleaning with brake cleaner, just check it for swarf as well.
chris.p
15
29-Apr-2013, 07:02
dunlop0_1
Jonzi
Evening
Is there any thing else that I should do between races?
More track days.
dunlop0_1
Send a personal message to dunlop0_1
Send email to dunlop0_1
Find all posts by dunlop0_1
16
29-Apr-2013, 08:18
SeeleyG50
: 500 Pantah, TT2, 749R, 944ssie, Rickman Kwak 1170, Yam 1200 Super Ten
: The Older I get the Faster I Was!
Spjallen
Oil every meeting. Filter every other including the strainer.
That's a shocking waste of good oil Si
Unless you are then using it for Salad Dressing?
SeeleyG50
Send a personal message to SeeleyG50
Send email to SeeleyG50
Find all posts by SeeleyG50
17
29-Apr-2013, 15:21
bally71
: 620SS Desmo Due 800SS Minitwin 1000SS Monster 750
: Inquisitive cat
Jonzi
hatch a cunning plan
bally71
Send a personal message to bally71
Send email to bally71
Find all posts by bally71
18
04-May-2013, 19:35
Yogi
Found it !
It's under the temp. sensor housing nut (21mm) situated just under the clutch casing.
There is also a drain bung directly below it, accessed form underneath.
Yogi
Send a personal message to Yogi
Send email to Yogi
Visit Yogi's homepage!
Find all posts by Yogi
19
05-May-2013, 10:49
Ghost
Yogi
Found it !
Err, told you that in post #11.
Ghost
20
05-May-2013, 14:15
Yogi
It has to be spelled out in fine detail for us thick Northerners.
Yogi
Send email to Yogi
Page 2 of 2
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:31.
