General Motorcycles only
Old 27-May-2013, 12:57   #1
Jasper Jasper is offline
Jasper's Avatar
Ohlins fork help needed-996RS
Hi,
does anybody know what the upper and lower fork clamp sizes are for these forks? I am confident the top yoke is 54mm. I just need to know if the bottom should be 56mm or 57mm!
I need to machine a set of Mag yokes to take them but do not have the forks to measure. The readings vernier I have been sent vary over 1mm which is not accurate enough!
Old 27-May-2013, 13:04   #2
Jasper's Avatar
some more pics:
Old 30-May-2013, 05:04   #3
Quarrybends Quarrybends is offline
Quarrybends's Avatar
Safest bet is to call uk importer or official ohlins agent, quote the model number as the RS could of been fitted with a multitude of forks. Spares are still available and I'm pretty sure the specs are too.
Old 30-May-2013, 10:40   #4
Jasper's Avatar
No model number mate. That's the problem.Hoping someone may recognise them.
Old 30-May-2013, 17:19   #5
The forks I have for my 955 are 54mm top and 58mm lower
I wouldn't trust the calipers in the pic, I was using a similar digital set the other day and they had a bit of a dead spot OK up to a certain measurement and then OK after a different measurement, but in between the two they were far from accurate, Dallas has probably binned them by now
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:09.
