Old 23-Jun-2013, 12:10
Having ridden Phils with the 916 tank I'm a convert: easy to get round than an SS but still tuck right in and use your knees on the tank (which is tough on a monster)
I love the idea of a 1100s engined, ohlins shod road bike built with 916 tank, clip ons and desmo bodywork.
Old 23-Jun-2013, 13:02
Campo's Avatar
Campo Campo is offline
Bikes: Class B 600ss #99
Originally Posted by bally71
Have you ever heard of these guys
www.radicalducati.com
some nice inspirations on there
I watched a couple of their vids on you tube a while back. They do do some real nice bikes.
Old 23-Jun-2013, 17:42
916 Nose cone on this one
Since taking the pic the bike has now grown a set of calipers, throttle, grips and a start switch
Mastercylinder and front hoses next
Bit more Progress
Click image for larger version Name:	Mk2_1011.jpg Views:	551 Size:	195.2 KB ID:	13601
Old 23-Jun-2013, 23:37
vespa's Avatar
vespa vespa is offline
Bikes: Super Twin 800; DD B; S2R 1000
Mood: DD class B
I will try this on Wed at Castle Combe.
It is a convertible SuperTwin/Streetfighter
based on a 900ssie donor with 804 engine.
Click image for larger version Name:	stsf.1.jpg Views:	573 Size:	532.1 KB ID:	13604
Old 24-Jun-2013, 23:10
Attachment 13604
Castle Combe will explain the standard exhaust, only chance of getting it through noise testing.
Got to decide what to do with the forks in mine
I have hopefully sorted out the Cartridge fork conversion Dallas tried twice last year with dismal results, now that the internals are in the correct externals they should work.
But also building up a set using 996 internals in 750SSie Dark Outers with 1000SS fork caps
Trouble is both sets are a good 40mm longer than the adjustable Monster S4 forks currently in it, so I may have to have a lot protruding above the top yoke and run 54mm clipons
Old 25-Jun-2013, 07:24
bally71's Avatar
Mood: Inquisitive cat
Attachment 13604
I've got a nice pair of high level pipes for that if you where interested
Old 25-Jun-2013, 07:34
vespa's Avatar
Mood: DD class B
PMS
thanks
  #18
Old 25-Jun-2013, 11:20
bally71's Avatar
what's the advantage with the 996 internals?
And wouldn't they be better off in 996 forks?
  #19
Old 25-Jun-2013, 17:22
They are intended for a Sports bike unlike the internals in ST and Monster S4 forks
Not when you see the state of the outside of the 996 forks, the braided hoses had rubbed through the anodising and then the corrosion set in, talk about scabby, those parts will be heading for the skip. Mind you it did make them very cheap.
Besides my 996 has already had its forks upgraded, re-anodised, Ti coated and billet lowers with 40mm mount for the 6-pot Calipers
  #20
Old 25-Jun-2013, 17:35
I'm not the first to do it by a long way, Chaz has been doing the fork conversion for a few years now and Tom Roberts and Simon Allen have had theirs done,
But when searching for more info on it I came across this
http://www.ducatisuite.com/monstersbkforks.html
And there are few mentions of it in the DSC archives
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:43.
