Old 25-Jun-2013, 23:16   #21
bally71's Avatar
Mood: Inquisitive cat
Suspension scares me .. the thought of taking forks apart makes me positively poo my pants
Old 25-Jun-2013, 23:46   #22
I first started pulling forks apart in 1980 to convert my 400/4 to a twin disc front end with better calipers, so i used the lowers from an XS250
one bike I wish i still had
Old 01-Jul-2013, 16:30   #23
But also building up a set using 996 internals in 750SSie Dark Outers with 1000SS fork caps
Be nice if someone hadn't already botched the 996 internals
Click image for larger version Name:	996 Fork.jpg Views:	282 Size:	163.3 KB ID:	13612
Old 02-Jul-2013, 01:57   #24
bally71's Avatar
The cap looks ok .... might make a nice paperweight
Old 04-Jul-2013, 00:04   #25
Caps no good for a DD bike as its to big
Forks are now all assembled, just need to add oil, set the appropriate air gap and see how the after market seals hold out
Old 22-Jul-2013, 00:08   #26
Not a lot of Progress of late
Just modified the 748 tank, fitted the pump and plumbed in the fuel connections.
Also did a bit of prep ready for the lock wiring
Hopefully tomorrow Dallas will weld on a couple more brackets for me so I can make a battery mount and then I can crack on with the electrics
Photos may be of use to Roxy
Click image for larger version Name:	DSC Tank Mod.jpg Views:	302 Size:	108.4 KB ID:	13638  Click image for larger version Name:	DSC Pump.jpg Views:	291 Size:	144.3 KB ID:	13639  Click image for larger version Name:	DSC Tank With Pump.jpg Views:	284 Size:	96.0 KB ID:	13640  Click image for larger version Name:	DSC Lock Wire.jpg Views:	298 Size:	114.2 KB ID:	13641
Old 22-Jul-2013, 22:21   #27
PHIL-THE-DRILL PHIL-THE-DRILL is offline
Bikes: 999 bip zx6r DD
PHIL-THE-DRILL's Avatar
Looks good Kev how about streetfighe r style like mine ?
Old 24-Jul-2013, 10:46   #28
mark 999 mark 999 is offline
Bikes: Anyones
mark 999's Avatar
They are indeed of use !
I've just about got all the bits ready for the project, although I've no idea where the battery is going to go !
Old 24-Jul-2013, 20:25   #29
Here's a clue
Click image for larger version Name:	Battery.jpg Views:	288 Size:	54.7 KB ID:	13645
Old 24-Jul-2013, 21:55   #30
Spjallen Spjallen is offline
Yes Chaz did my forks and I've had no real issues with them ( sensible money for the work too) it gave me the adjustabilty I was after. Serviced them this year and changed to a slighly heavier fork oil which I prefer - 5w to 7.5w. A job worth doing.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 00:44.
