  #21
Old 25-Jun-2013, 23:16
bally71's Avatar
Mood: Inquisitive cat
Suspension scares me .. the thought of taking forks apart makes me positively poo my pants
  #22
Old 25-Jun-2013, 23:46
I first started pulling forks apart in 1980 to convert my 400/4 to a twin disc front end with better calipers, so i used the lowers from an XS250
one bike I wish i still had
  #23
Old 01-Jul-2013, 16:30
But also building up a set using 996 internals in 750SSie Dark Outers with 1000SS fork caps
Be nice if someone hadn't already botched the 996 internals
Click image for larger version Name:	996 Fork.jpg Views:	240 Size:	163.3 KB ID:	13612
  #24
Old 02-Jul-2013, 01:57
bally71's Avatar
The cap looks ok .... might make a nice paperweight
  #25
Old 04-Jul-2013, 00:04
Caps no good for a DD bike as its to big
Forks are now all assembled, just need to add oil, set the appropriate air gap and see how the after market seals hold out
  #26
Old 22-Jul-2013, 00:08
Not a lot of Progress of late
Just modified the 748 tank, fitted the pump and plumbed in the fuel connections.
Also did a bit of prep ready for the lock wiring
Hopefully tomorrow Dallas will weld on a couple more brackets for me so I can make a battery mount and then I can crack on with the electrics
Photos may be of use to Roxy
Click image for larger version Name:	DSC Tank Mod.jpg Views:	260 Size:	108.4 KB ID:	13638  Click image for larger version Name:	DSC Pump.jpg Views:	248 Size:	144.3 KB ID:	13639  Click image for larger version Name:	DSC Tank With Pump.jpg Views:	240 Size:	96.0 KB ID:	13640  Click image for larger version Name:	DSC Lock Wire.jpg Views:	254 Size:	114.2 KB ID:	13641
  #27
Old 22-Jul-2013, 22:21
PHIL-THE-DRILL's Avatar
PHIL-THE-DRILL PHIL-THE-DRILL is offline
Bikes: 999 bip zx6r DD
Looks good Kev how about streetfighe r style like mine ?
  #28
Old 24-Jul-2013, 10:46
mark 999's Avatar
mark 999 mark 999 is offline
Bikes: Anyones
They are indeed of use !
I've just about got all the bits ready for the project, although I've no idea where the battery is going to go !
  #29
Old 24-Jul-2013, 20:25
Here's a clue
Click image for larger version Name:	Battery.jpg Views:	244 Size:	54.7 KB ID:	13645
  #30
Old 24-Jul-2013, 21:55
Yes Chaz did my forks and I've had no real issues with them ( sensible money for the work too) it gave me the adjustabilty I was after. Serviced them this year and changed to a slighly heavier fork oil which I prefer - 5w to 7.5w. A job worth doing.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:25.
