Old 23-Aug-2004, 11:20   #1
regular 72 regular 72 is offline
Luggage rack 749
Has anyone got good or bad experiences with a luggagerack for a 749 monoposto?
Pictures perhaps..
I look forward to hear from you!
[Edited on 23-8-2004 by regular 72]
Old 23-Aug-2004, 11:24   #2
Scottch Scottch is offline
Mood: Is it summer yet?
Reg,
Try gettin in touch with redistwincherries.
He has a neat little sportsrack on his R.
Cheers!
Scott
Old 23-Aug-2004, 13:40   #3
Mood: going for a ride...
or even yellowisfriedegg...........................
I have a Ventura rack for my 749R , excellent piece of kit , half an hour to fit tops
It just bolts to the main frame at the same points as the subframe using spacers and longer bolts , highly reccomended
Old 23-Aug-2004, 13:49   #4
Loz Loz is offline
Loz's Avatar
Isn't there a slight hiccup with Termis and fitting the Ventura? It can be done but there's a problem with clearances?
Or maybe I dreamt that.
I have a Ventura rack on my 999S Bip. Slight problems fitting mine but got there in the end.
Old 23-Aug-2004, 14:13   #5
I've just rang the 'Ventura' importer in The Netherlands to get some specified information. As it is a rare product they could not give the necessary confidience..
Because mine is a monoposto version you are not enable to use the passenger footrests. I'm a bit afraid the complete construction will become a bit instable and even worse will cause damages to the paintwork.
@ yellowisfriedegg; do you have detailed pictures of your Ventura. Did you use different bolts and spacers to keep the rack away from the paintwork?
Would it matter having a Termignoni fitted on my bike?
Old 23-Aug-2004, 17:22   #6
My bike has a termi system fitted too , the Ventura rack for the mono bike is completely different to the one for the bip model.
There is no problem with clearances , the spacers and bolts come in the bag with the rack.
I will take photo's tonight if I get time.
Old 23-Aug-2004, 17:25   #7
If you are having problems with the importer in the Netherlands , phone Motohaus in the UK :
(+44) 1256 704 909
Old 23-Aug-2004, 18:31   #8
Look forward to see the photo's.. Thanks!
Old 24-Aug-2004, 08:17   #9
Here is a photo , sorry about the quality , used the phone :
Old 24-Aug-2004, 10:34   #10
Here is another photo showing the mounting points and spacers , the rack is mounted from the main frame / subframe mounting lugs only , no load is put into the subframe unlike the bip version.
The rack can only be positioned as shown , unlike the bip version which can be positioned facing either backwards or forwards depending on if you have a pillion passenger or not
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:36.
