Old 30-Oct-2013, 19:47   #1
Campo Campo is offline
Bikes: Class B 600ss #99
Campo's Avatar
Cambelts?
Should I change my cambelts for next season although I've only done one race weekend, a trackday and a test day?
Old 30-Oct-2013, 20:17   #2
how long since the last change?
it's probably a good idea to remove the covers and inspect them for any kind of damage or wear, and check the tension, but they should be good for a couple of years.
Old 30-Oct-2013, 20:25   #3
Only £20 and worth doing if you're not sure. It's not worth the worry or the risk.
Old 30-Oct-2013, 20:25   #4
Campo's Avatar
Only fitted them this May or June
Old 30-Oct-2013, 20:35   #5
Providing they have been tensioned correctly and not been run to tight I would leave them on and just check them between meetings and readjust if they become slack.
Every so often it is wort removing them to check the condition of the bearings in the tensioner and idle roller. but remember to refit the belts so they are not only matched to the same cylinder but also run in the same original direction
Old 30-Oct-2013, 21:01   #6
dunlop0_1's Avatar
£20 Where do you shop ?
Old 30-Oct-2013, 21:05   #7
Bikes: 900ss 600ss xr400
milesaway's Avatar
could probably do this by just slackening and not have to remove them-
done 2 seasons on mine just checked tension once or twice- change every 2yrs is ducati line on it- also belts have been improved since these bikes first made and now have kevlar in
Old 30-Oct-2013, 21:08   #8
milesaway's Avatar
simon only runs 1 belt and does 1 season on front cyl next on rear to save wearing them both out at once
Old 30-Oct-2013, 22:03   #9
Campo's Avatar
Thanks for the advice. I will keep them on and keep my eye on them
Old 30-Oct-2013, 23:59   #10
£20 each. Sorry forgot that bit! ebay of course pieman!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:04.
