Old 06-Sep-2004, 15:22
748 non-starter
Hadn't ridden the bike for a couple of weeks and battery was flat (starter motor turned over but feebly). I tried to bump it first, the odd splutter but no joy (frankly I thought I was going to have a heart attack after the fifth attempt), so charged the battery. Now though fuel-pump and other electrics are functioning, nothing doing with starter motor. Checked fuses, and cleaned connections to starter motor and relay (relay was replaced 2 months ago), still no joy. I'm thinking starter motor is fried but any other suggestions before I go down that road?
One anomaly is the Datatool Veto immobilizer will only stay in 'Service' mode ie the alarm goes off when it's put in parked, 'normal' mode.
TIA for any advice.
Old 06-Sep-2004, 18:20
HANCYM HANCYM is offline
Not quite sure what you mean about the Alarm. I have a Veto fitted to my 748 and that will only disable the tilt switch from Normal mode. You have to switch the ignition on and press the button to enter service mode. Is that what you mean isn't happening.
Anyhow, on the subject of your battery. My alarm will Eat the battery in day and so did the Motoguard I had fitted on my ZX9R and so did the immobilizer I had on my Golf GTI. I would guess from my experience that most after market Alarm/Immobilizer eat batteries.
What I've done, instead of using an Oximizer or similar. I've wired a nice sexy little power supply socket to the dash on my bike with a diode and fuse in circuit (so you can't short the bikes electric’s). I then converted a small plug in power supply with a Regulator chip to hold the voltage at 13.8v. Every time I park the bike up I plug in. Much more convenient and won't overcharge the battery. Gone off at a a tangent really! Not sure what's causing you starting probs but maybe this will help you preserve you new battery
Old 07-Sep-2004, 09:24
keith_mann1959's Avatar
Bikes: ST4S
Is this not what an optimate or similar does.
Old 07-Sep-2004, 09:57
748mart 748mart is offline
Place a spanner across the 2 large solenoid terminals (be ready for the sparks) , if battery & starter are OK engine will crank over & should start. This will confirm faulty solenoid, control wiring or switches.
If it dosn't crank over try jump starting from car to eliminate battery. probably best to not have car engine running to minimise possibility of damaging bike cpu etc.
Old 07-Sep-2004, 18:52
Going with this one, same thing happened to me, even after new solanoid fitted, check that the small middle wire is firmly home as well.
Chris.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:05.
