  #21
Old 02-Mar-2014, 11:12
milesaway's Avatar
Bikes: 900ss 600ss xr400
Almost 3 weeks on and nothing has changed on my 2014 projects
price you pay for swanning off to the dessert while we all hiding in sheds from a monsoon
  #22
Old 07-Mar-2014, 19:10
Progress at last
New Chain sliders/guides, New Chain and New Case Guard fitted
Small Allen bolt behind the front sprocket lockwired
Forks swapped from ST2 adjustable ones to 750 Supersport ones containing Mupo Cartridges
Bars now fitted above the yokes
Still quite a bit to do such as fitting a Reg/Rec, Tacho, Seat Pad, along with sorting out the gear change, bellypan, battery retainer and the fairing mount that the Brake Mastercylinder fouls on soon as you add a bit of left lock
Click image for larger version Name:	#1.jpg Views:	942 Size:	158.4 KB ID:	13869  Click image for larger version Name:	#2.jpg Views:	986 Size:	150.3 KB ID:	13870
  #23
Old 08-Mar-2014, 09:31
milesaway's Avatar
not much time left now kev!
think i've done all i can to mine for now and serviced my van ready- will i be able to weigh mine at brands before we start to check i haven't taken too much weight off it? (my attempts with bathroom scales not to be trusted!)
  #24
Old 08-Mar-2014, 10:08
Luckily for me last years bike is ready to go
I'm Not sure what weighing Scales will be available at Brands if any
  #25
Old 16-Mar-2014, 18:34
All the above now sorted, so nearly ready for its maiden outing on the Brands Test day.
Just waiting for the seat foam to arrive the only things left to do are oil and filter change, then lockwire everything up. Then make some spacers and brackets and get the Bellypan fitted.
Click image for larger version Name:	#3.jpg Views:	937 Size:	140.7 KB ID:	13877  Click image for larger version Name:	#4.jpg Views:	967 Size:	158.7 KB ID:	13878
  #26
Old 17-Mar-2014, 10:18
Blimey... Nearly a Grand!
(But cheaper than Ohlins cartridges )
  #27
Old 17-Mar-2014, 21:23
Less than half of that Frank
Dallas bought them for the 2012 Desmo Due season and at the first round at Brands he had to remove them as they just didn't work, he returned them to Go Racing Developments where he got them and they handed them back a few weeks later saying they should work now.
So at Snetterton he tried them again, after one session they were back out of the bike.
I did him a deal against some other bits and then whipped them out of the ST forks they were in and put them in a set of Longer Supersport ones as they had been trying to extend the ST forks to far.
Hopefully I will get to see if they are now working on Friday, but have no info on oil grade or air gap. So will probably need some set up time but so long as they don't stick like they did to Dallas,
I will know I'm going in the right direction, he came in from the session at Snetterton with over 2 inches of travel not used. So I want to see my cable tie less than an inch from the bottom casting after a session and I'll be happy
  #28
Old 28-Mar-2014, 20:51
well I can't say Brands went to plan as the new bike just didn't want to run right and by the time I had cleaned the fuel pump and changed the fuel filter to get it running properly there were only a couple of sessions left in the day to get out on it.
I used the first of those sessions to Scrub new tyres on the race bike and then went up to pit lane for the final session to try out the new bike. Only to have the final session canceled due to an incident on track where a couple of bikes came together and then deposited Antifreeze on to the track.
Still even just riding it up to the pit lane and back and a couple of times around the lower paddock I gathered some info on things that need sorting
Firstly the seat is to low, so I will be adding an extra layer of foam.
The standard allen bolts for the footrest plates catch on my boots so they will be replaced with domed headed bolts.
The clutch needs looking at and possibly replacing as there is a lot of drag and a nice lurch forward every time I put it in gear.
So tomorrow I will start looking at addressing these issues
  #29
Old 30-Mar-2014, 09:24
Right that's the Allen bolts changed and hopefully the Clutch is now sorted
Click image for larger version Name:	DSC.jpg Views:	930 Size:	179.5 KB ID:	13893
  #30
Old 04-Apr-2014, 08:53
badgerpilot's Avatar
D1ckheads, Bernie the scrute was complaining about this when I took the poorly Badger to him after our tumble.
Could this have a bearing on why 3 of us had the same crash at the same part of the track within 5 seconds of each other and all 3 offs totally separate?
Scott #50
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:54.
