Old 31-Mar-2014, 21:36
Mykie916's Avatar
Mykie916 Mykie916 is offline
Bikes: 98 916, 2006 Blade, DD Class B #20
Engine year
How do I find out which year my b class DD bike engine is from ? Myk
Old 31-Mar-2014, 22:19
If the clutch slave is on the left it's a late Monster engine. If it's on the right then its a pre 99 engine and depending how far out the output shaft protrudes determines if its pre 95 or not
Old 31-Mar-2014, 22:35
milesaway's Avatar
Bikes: 900ss 600ss xr400
yours is a pre 1870 steam version
Old 01-Apr-2014, 14:17
Mykie916's Avatar
Pmsl that explains a lot !!
Old 01-Apr-2014, 14:19
Mykie916's Avatar
Looks like I'll be measuring my shaft later then ooh matron
Old 02-Apr-2014, 20:33
Mykie916's Avatar
Output shaft 42mm, clutch slave on the left
Old 02-Apr-2014, 22:41
As already mentioned to you Myk yours is a Late Monster engine circa 99 to 01
Has a 1.85 to 1 Primary drive ratio and standard gearing for a Monster was 15/46.
600 Supersport models were no longer made at that point but if they had of been Ducati would have done what they normally did and dropped the rear sprocket down to a 44.
in 2002 the Monster became a 620 and the 620 Sport was introduced, gearing was 15/46 and 15/44 respectively
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:31.
