Old 29-Sep-2004, 14:56
Steve Steve is offline
Fairing lowers with belly pan
Does anyone know if you can buy fairing lowers with the belly pan built in or cut to accept a seperate belly pan
Old 29-Sep-2004, 16:20
On my Bostrom the fairing lowers include a carbon bellypan, so am I correct in assuming that any 998/996R lowers will do the job? You'd also need to replace your V-Piece to suit
Old 29-Sep-2004, 16:56
Forgot to mention it's for a 748 - if that makes a difference
Old 29-Sep-2004, 17:47
Clippy's Avatar
Clippy Clippy is offline
Bikes: 1098
Mood: Enjoying a REAL summer!
Lowers and belly...
You will need to buy a matched set of side panels and belly pan I think.
On my genuine Ducati track day bodywork (so presume it's the same with painted up rod panels) the lowers are shorter and will need to be drilled to accept the dzus fastners that hold the belly pan on.
I've kept my standard carbon v-piece though - it fits over the front edge of the belly pan nicely.
Giles
Old 29-Sep-2004, 19:43
could try ard racing, they do body kits which include a drip tray
Old 29-Sep-2004, 20:49
Yes you can as I have one but I have no idea where it originally came from, I'll try and put up a photo of it on here later.
Old 29-Sep-2004, 23:10
neil748r neil748r is offline
Both Casoli and QB Carbon do them. Pretty sure they'll also do them in fiberglass at less cost.
Personally I wouldn't touch either with the proverbial barge pole but the options there if you want to go down that route.
[Edited on 29-9-2004 by neil748r]
Old 29-Sep-2004, 23:34
I have one fitted which is 1 piece lower and bell pan - make fitting awkward and I would have preferred to have had it so the lower is removable via dzus (if that makes sense??)
www.ardracing.com just found the link
Old 30-Sep-2004, 09:24
cheers fellas
Old 30-Sep-2004, 19:41
The pic at last
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 04:25.
