Old 04-Oct-2004, 17:38   #11
cmoss cmoss is offline
Got a call from Ducati Manchester 4 rockers and a cam shaft. That's only the engine inspection, will wait to see what else needs replacing. There trying to make, an out of warranty claim !!!! best sign up for another credit card!!!
Old 04-Oct-2004, 17:52   #12
I am guessing it's out of warranty then? How old is your bike?
Old 04-Oct-2004, 17:56   #13
Ducati 996 BP registered 2002, Not really hammered it that much, no track days yet, just getting the bike ready for them next year.
Old 04-Oct-2004, 18:19   #14
Hmmmm....
Does it feel like it's firing on one cylinder every now and again?
Old 04-Oct-2004, 20:40   #15
Hard to say, I've run the bike with only one cyclinder firing, forgot to connect the plug to HT coil after fitting crash bungs and it dosn't feel like that. Hopefully once they have completed the service they can then start to find out about the spluttering, may be TPS or possibly ECU fault. Should find out later on this week how things are going
Old 04-Oct-2004, 21:05   #16
Be interesting to see what they find, and if Ducati honour the warranty etc
Old 04-Oct-2004, 21:08   #17
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Is it on 2 or 4 injectors. The 4 injector setup is known to be a bit spluttery. FIM chip and tie off two injector feeds, different bike.
Rgds, Rob
Old 04-Oct-2004, 21:39   #18
It is a 4 injector model, but this has only just started to happen, have never noticed any problems upto now. Had bike one year. Will see how things go.
Old 05-Oct-2004, 15:37   #19
ziggi ziggi is offline
ziggi's Avatar
cmoss - this sounds like exactly the same problems I had after my first 6000 mile service. When I got it back is was crap, wouldn't run at low revs, popped and crackled on overrun and basically was only good flat out. The bike was re-shimmed and basic other stuff.
I took it to Sigma Performance and had FIM Ultimap chip and some fettling. Bike was transformed.
As far as I remember, there's only 2 injectors - you can get FIM chips to run with 1 or 2 injectors. I could be wrong though. Mines still running on the 2 injector setup with FIM ultimap UM239 chip (but this is for the 996S so don't get that one).
Cheers, zig
Old 14-Oct-2004, 11:41   #20
yorkshire pud yorkshire pud is offline
Mood: poon tang
i would check, your relays. had water in mine once farting. everyware. wd40, godd as gold.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:49.
