Old 23-Oct-2004, 14:31
Mood: Come on spring!!!
rear light fitting??
Ive just been putting the rear seat back together, after having it painted, (mono) and after pushing the light unit onto the spigots that go thru the grommets it seems to droop out of the aperture.
Am i missing somthing here or do i need to put some double sided tape in their as well??
Old 23-Oct-2004, 14:37
NBs996's Avatar
NBs996 NBs996 is offline
Mood: I love my 996 xxx
sounds like you're missing the little rubber 'wedge' that goes right at the back of the light. 81p +vat. Item 28 in attached pic
[Edited on 23-10-2004 by NBs996]
Old 23-Oct-2004, 15:09
Thanks
Thanks for the quick reply thats excellent.
Old 23-Oct-2004, 15:15
NBs996's Avatar
what can I say, I'm bored and it's raining!
Part no. 86610181A if that helps.
Old 23-Oct-2004, 15:24
Mood: Avatar what Avatar
ME too NBs99s
bored as well and yes the little rubber wedge that should do it
Old 23-Oct-2004, 15:40
well
well if your mega bored i dont suppose you can find me the part numbers for the following and best place to mail order from could you??
For a 2001 748R
Pair of airtube seals
Rubber screen fixing nuts
Rubber grommet for the v piece spiggot to fit in the oil cooler
and both right hand side grills for the mono seat unit?
Thanks
Old 23-Oct-2004, 16:11
Haven't you asked this before !
I made my own useing DAX foam works well but I have jhp undertank filtter.
part no for the screw and rubber well nut is 69920721A
That comes as one screw and one wellnut cost me £4.00 each not cheap I am sure someone will no of an allternative ?
Old 23-Oct-2004, 16:24
NBs996's Avatar
For a 2001 748R
Thanks
ok, from the top of my head (or even the parts list!)....
rubber nuts: 69920721A (includes the screw and washer too)
v piece grommet: 800069069
air tube seals: 78810441A/78810451A
side grills.... will have to get back to you on that!
as for mail order.... have a word with neil at Cornerspeed, he'll see you good.
Old 23-Oct-2004, 19:13
bolds bolds is offline
Hi
The rubber well nut on its own for screen 75010241A .70p
Rh grills 46010521B (large) £2.20 and 46010531A (small) £2.83 all plus VAt
Old 23-Oct-2004, 19:17
thanks
Thanks alot you guys been a great help!!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:19.
