Old 10-Mar-2015, 21:16   #1
Nat1975 Nat1975 is offline
28 Ah battery
Hi all, just bought a 1993 900ss. Joined this forum as I'm going to need lots of advice.
First bit of advice needed is regarding the battery. Mines finished. Charged the battery, multimeter said 12.63 volts a couple of days ago. Tried to start the bike tonight and it only turned over three or four times, then nothing.
So, new battery. I found one from Eurocar parts. (Which I have an account with)
Exide Y60-n24l-a this has 28Ah. Is this to much? Or is it the more Ah you have, the better?
Cheers, Nat.
Old 10-Mar-2015, 23:08   #2
Fully charged should be 13.2 volts but 12.63v isn't to bad but that's only unloaded and it looks like loading yours soon drags the volts down
16Ah is normally enough for most Ducatis as it's standard on many from the 90's, i would have thought 28Ah would be physically to big a battery
Old 11-Mar-2015, 19:37   #3
Just compared measurements. Your right, much to big.
So, any recommendations on which battery to buy. Want to stick with lead acid and not the gel type (something I read on here)
Old 11-Mar-2015, 22:56   #4
I think it was a Odyssey battery everyone use to recommend
Not cheap but everyone that had one swore by them
http://www.tayna.co.uk/Odyssey-Batteries-S73-1.html
Old 12-Mar-2015, 08:49   #5
Give the lads at MDS battery a shout, they sorted me an uprated acid battery out years ago a YTX series if I remember...
http://www.mdsbattery.co.uk/shop/pro...uctGroupID=839
I think it was the one above but easier to phone as tech has moved on...
Old 12-Mar-2015, 18:43   #6
Thanks for that. Will ring them tomorrow.
The Odyssey one is a bit rich for me. I need to spend wisely on my new toy as it needs quite a bit doing to it.
Cheers, Nat.
Old 18-Mar-2015, 13:32   #7
Fruitbat Fruitbat is offline
Bikes: Hypermotard, 600ss
Fruitbat's Avatar
Mood: Positively pensive
Motobatt seem well regarded as a value for money gel battery, sold by M&P amongst others. Will be one I'll consider when the current Westco AGM item finally expires (tho that could be a while yet as it just seems to keep on keeping on).
At the other extreme I had a 18ah lighweight Shorai in my Hyper, the cost of which I justified to myself by the 2.5kg+(?) weight saving from a location high up in the tail. None available in the UK when I was looking 4 years ago so I had one sent over from the States by a mate. Cheaper than buying in the UK but still not inexpensive - but I reckon it's good value as it's a superb bit of kit.
You seem to need a dedicated charger (not a trickle charger) but that's not really an issue as it's happy to hibernate for five months over the winter without a top up. Once you've woken it up by putting a light load on it for a minute or so it's good to go.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:29.
