Old 01-May-2015, 22:06   #1
pbrown pbrown is offline
SS frame & carb vs ie
OK so I'm seeing lots of issues with ss frames cracking. Can this be sorted by fitting a bolt on tube or does it need a welded stiffener/tube across where the top tubes bend?
Another one is how much difference or better the injection is compared to carbs?
Some of this is for a road based 900 & rest is for ss based desmoduo.
Been away from Dukes for over a year and need my fix & to get back into them.
Old 06-May-2015, 10:17   #2
do ss frames crack? i've "tested" mine fairly comprehensively and not had any frame related issues.
Old 07-May-2015, 21:04   #3
bally71's Avatar
Mood: Inquisitive cat
I've thrown mine down the road a few times .. reckon you'll crack before the frame will
Injection v's carbs ... for the road .. wouldn't make any odds
For the track ... Wouldn't make any odds because you'd only be racing against like for like
Old 07-May-2015, 22:00   #4
I'd go for the later one with the 24 degree rake over the older model with its 25 degree rake.
My 600SS frame developed a crack in the top frame rail just along from the headstock. I drilled a small hole at each end of the crack and then had it welded
Never had this with my 750SSie that I raced in Minitwins or my 1000SS
Old 11-May-2015, 21:38   #5
paynep's Avatar
Mood: Wet wet wet
The later frame weighs a couple of kg more though! I can't remember exactly how much but they are written on my garage wall if you do want to know.....
PP
Old 12-May-2015, 12:20   #6
Thanks Gents,
I hadn't realized they'd changed the rake over the years so I need to do more investigating.
Skidlids, that's exactly the location of the cracks I'd been hearing about. No problem with getting it welded up?
Not sure whether It's correct but I've seen comments that the very early frames were CrMo & not known to crack then they went to CS & frames started to crack. When you look at the frame you can see it could do with a brace between the upper tubes to hold them together but that would cause problems with the air box.
Also seen comments on tube wall thickness increase to reduce cracking so maybe that's why the later frames weigh more.
The carb vs injection was more for the road going 'keeper', wasn't sure on ease/cost of maintenance between them?
Old 13-May-2015, 00:25   #7
You can't quite see the weld, just the blue paint that I added to protect it from the rain
Click image for larger version Name:	#Crack101.jpg Views:	1206 Size:	288.1 KB ID:	14278  Click image for larger version Name:	#Crack111.jpg Views:	1189 Size:	318.1 KB ID:	14279
Old 13-May-2015, 15:03   #8
That looks like top of top tube. I thought it went on the inside of the top tube where the gusset weld is.
Old 26-May-2015, 15:38   #9
stafford stafford is offline
Bikes: 888 Strada 888 Classic TT S2R1000 1000SS ST4S 900SSie M750 600SS
stafford's Avatar
Mood: Looking for speed
You can get a frame brace to support the affected area.
Old 26-May-2015, 15:39   #10
Is the brace bolt on or welded?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:20.
