Old 06-Nov-2004, 09:55   #11
Kind of changed my mind a bit on this one. I did the belts on my ST2 using the allen key method and it was never a worry. Nelly did the belts on the ST4. I'm just kinda wondering now how i would have felt at 10,500 rpm on the start/finish straight at Snetterton if one had let go? At least if you get a dealer to fit them then you can go and kick his arse if something goes wrong! (not that i ever would almost a year after they were done!)
Old 06-Nov-2004, 10:14   #12
Jen you can find info here
http://ducatisportingclub.com/contro...d.php?tid=1134
http://ducatisportingclub.com/contro...d.php?tid=3807
Correct link in fianal post at bottom of the page to Facom tensioner £79 at the time
Kev
Old 06-Nov-2004, 11:32   #13
FiscusFish's Avatar
Originally posted by nelly
I use the factory tool for the 4V's engines and the old fashioned way of tensioning by feel and a 5mm allen key on the 2V's.
I always run the rear cylinder a little tighter than the front one to, not much though, to allow for the temp. differences.
Rear one tighter? Doesn't the rear cylinder get hotter though so you should be running the belt looser to allow for increased expansion? 5mm front 6mm rear type difference? This is the 2 valve of course.
Darren
Old 06-Nov-2004, 21:30   #14
desmojen desmojen is offline
Mood: DOH!
Kev
Cheers Skids
Old 07-Nov-2004, 01:08   #15
Darren
yep..............sorry. It was 1-30am
Old 08-Nov-2004, 12:19   #16
chris_of_1979 chris_of_1979 is offline
Mood: I'm Bad!
Well - have decided to take the sensible appraoch and book it in with a dealer - like some have said, its only a small saving to do it yourself, and the risk is a worrying factor.
Ducati Aylesbury are doing the job.
How does £130 sound? (including them collecting the bike and dropping it back - 30miles away)
Old 08-Nov-2004, 20:43   #17
Fordie Fordie is offline
Regional Organiser - BHCN
Fordie's Avatar
Mood: Raring to Ride
Sounds about what I was charged,but I had one of there 600's to blat about on for the day whilst they did mine .4D
Old 08-Nov-2004, 20:54   #18
sparkin sparkin is offline
sparkin's Avatar
Don`t want to give anyone the wrong info and I`m sure nelly will correct me if I`m wrong,but aren`t Ducati dealers now using the math` tester to check belt tension on the newer models in the range?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:34.
