Old 24-Sep-2015, 01:42   #1
NTA3 NTA3 is offline
Ohlins suspensions for my new project on 996
Hi
I am looking for Ohlins suspensions for my new project on 996,the question is can i use the Ohlins from 999s for my 996.
I know that front fender does not fit right way,and i know at the lower triple ohlins are 56mm and the showa is 53mm. I am interested to know if the calliper alignment will be an issue with my 996.
Thank you
Old 24-Sep-2015, 10:02   #2
You may find the calipers are out of alignment as the 999 uses discs with a 15mm offset, just as the 748R did. So the easy option is four 5mm spacers to go between the caliper and the fork leg and 5mm longer M10 x 1.25 caliper bolts
Old 24-Sep-2015, 21:09   #3
Thumbs up
Thanks !
If someone sell OHLINS forks for 784-996-998 that will be good to…
Old 07-Oct-2015, 19:30   #4
Hey guys,
I finally found what i was looking for !
Can I use the Showa 25mm axle for this Ohlins forks ?
Thanks
Old 07-Oct-2015, 20:52   #5
Yes, standard spindle will fit
Old 07-Oct-2015, 21:18   #6
Thumbs up
Thank you !!!
cheers
Old 07-Oct-2015, 22:20   #7
A photo of the front end in my 996 taken last weekend, which is how I know the standard spindle fits
Old 08-Oct-2015, 23:58   #8
Thumbs up
Nice
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 00:55.
