Old 26-May-2005, 22:41   #1
bossingit bossingit is offline
bossingit's Avatar
Mood: suns out...happpy!!!brm brm
swarf on my back wheel?
anybody got any ideas where its come from,took it for a long ride today,got off n noticed swarf stuck to some of the chain lube on the back wheel(only just done the chain oil thing),wondered if anyone could shed light,nothing feels wrong about the bike when i ride it!?!?!
Old 26-May-2005, 22:45   #2
m1keyp m1keyp is offline
It may be the cush drives wearing against the swinging arm!!!!
Old 26-May-2005, 22:48   #3
ericthered40's Avatar
Mood: renegade sexy racer
Look at your Cush drives make shore their not hitting your swing arm
they can come out the back if you have a standard sproket housing
Old 26-May-2005, 22:49   #4
guest1 guest1 is offline
Check also the spacer is in the correct way.
I had a tyre fitted and the spacer was put back the wrong way.
Old 26-May-2005, 22:50   #5
bossingit's Avatar
ok chaps,thanks for that,ill check first thing tomorrow
Old 26-May-2005, 23:39   #6
Mood: aving a laff
I had the same problem on my 996 a few years ago.
I have tried to search the old board for the thread but its not there, the old board, so from memory.
The rear sprocket carrier is held in place by a circlip spacer that sits in a machined groove in the sprocket carrier assembly.
With time this circlip wears the recess and allows the sprocket carrier to move which allows the sprocket carrier to chew the eccentric hub away.
there is a later eplacement spacer that does away with the circlip jobbie and Ducati know about this but they diod not do a recall but luckily mine was under warranty.
If you have caught it early enough your eccentric will still have enmough ali left for you to adjust the chain, if not its a full replacement and the new spacer will be required too.
HOpefully though it might just be a cush drive outer sleeve thats backing out of the carrier and you will just need the cushdrives replacing.
Either way its lucky you found it before it grabbed the eccentric and locked the rear wheel up whilst riding!
Good luck.
Old 26-May-2005, 23:51   #7
jc jc is offline
Mood: Donkey on the edge!!!!
Yep bang on about the cush drives,
I had the swarf affair 2 days before the lemans gp this year
If you spin back wheel around slowly ,you will see at least one cush drive rubbing on the chain adjusters on the swing arm
Luckily JHP had some in stock and bob's ya uncle and all that
Old 27-May-2005, 09:29   #8
Nattyboy Nattyboy is offline
Nattyboy's Avatar
Mood: Back down to 3 :>(
Ive got the later style hub with the spacer (new in box) if you need one BG..
Nat
Old 27-May-2005, 10:08   #9
bossingit's Avatar
today's the day ill check,hopefully its just the spacer...is it the kind of job you can do yourself?
Old 27-May-2005, 10:09   #10
bossingit's Avatar
natty,ill let you know if i need that part....im starting to be a regular customer!!!haha
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:24.
