Old 26-Sep-2011, 16:10
Red face Power Commanders
Guys, anyone got a good contact for power commanders for a 620 sport and what model fits, they seem to quote only a monster one - or am I being thick and this also fits?!!
Old 26-Sep-2011, 16:20
I've fitted a few different PC3 USBs including 998 and 1098 ones
Any with the 2-pin connectors that go inline with the feed to the fuel injectors
Old 26-Sep-2011, 17:03
paynep's Avatar
Mood: Wet wet wet
Originally Posted by Spjallen
Guys, anyone got a good contact for power commanders for a 620 sport and what model fits, they seem to quote only a monster one - or am I being new to Ducatis and this also fits?!!
Yes, for 620 Sport read 620Monster.
Or as Kev says, any that plug directly into the injector connector can be used*
*Not tried it myself but don't see why not!
Old 26-Sep-2011, 18:13
Chaz's Avatar
Chaz Chaz is offline
Bikes: 916 Strada
Mood: www.od2racing.co.uk
Or just get your ecu remapped cheaper option
Old 26-Sep-2011, 22:54
Chaz How much does Chris charge to dyno setup the standard ECU, probably looking at 3 maps to be tweaked, one for the fueling of each cylinder and one for the Ignition Advance something that can't be done with a PC3
I know I have added a PC3 and had it setup on a Dyno for less than £250 and that was getting the PC3 at a decent secondhand price
I also know Chris charges £249 to disable the IMMO system but you don't have to have that done if your happy to run coded clocks and key
Old 26-Sep-2011, 23:06
The only problem there kev, is that if the bike has a big tumble the clocks can get screwed, hence it is possibly cheaper to get the IMMO system disabled, another option is to get John at Track Electronics to build you a custom loom that does away with the IMMO and all the clocks etc, not cheap, but could be in the long run.
Old 26-Sep-2011, 23:14
CJS on his website says costs about the same as a PC plus fitting and set up - £450???
Old 26-Sep-2011, 23:46
Why a fitting charge as bikes already fitted with either a 59M or 5AM ECU so we should just be talking about the cost of setup on a Dyno.
And the price I see on the website ranges from £299 to £600 depending on how much gets mapped/altered. From what I can make out the bottom price of £299 is for remapping the fueling so similar to what you would be doing with a PC3. So if your bike doesn't already have a PC3 its a competive way to go and at extra cost you do get more options.
Old 26-Sep-2011, 23:56
Imola Duke's Avatar
If you use it to race then thats good
But this technology is bad imho.... knicked road bikes anyone ?
I cant see this going on for long and i'm surprised CJS advertise they offer this service!!
Old 27-Sep-2011, 00:12
If you have a big tumble and the clocks get screwed THEN you can spend the £249 to have the IMMO function turned off/disabled
But until then you don't need to spend the money although if you do you could recoup most of it if you can find a buyer for your clocks and Keys, unlikely it would be to a DDer as they would be looking at getting there ECUs done.
Maybe best to keep the £249 in your bank account I doubt if many Class A runners would have spent it by now in 7 years of DD
Its a great option if all you have to start with is an engine and harness as then all you need is a suitable ECU and have it setup on the Dyno for your bike with the IMMO function switched off, Think Kev P was told about £450 for this if he provided a suitable ECU
Just building a race loom doesn't do away with the IMMO function as the ECU still looks for it unless you have it turned off. so the cost of a loom on top of the £249 is a bit OTT for DD
Now if I was after a race loom I'd build it myself, after wiring Space Research Satalites in just white raychem wire a race harness is a doddle
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 04:41.
