Old 15-Nov-2004, 22:41   #11
Henners Henners is offline
As usual around here ..
.. acres of good advice. I can't add very much except I've just upgraded the brakes on my 916 with:
~ new stainless lines
~ new Dot 4 synthetic fluid
~ new Bendix pads from Cornerspeed - ask Nelly which ones
~ about two hours de-seizing the bl**dy brake calipers on the righthand side caliper
~ bleeding the air out of the top master cylinder joint
~ leaving a huge elastic band on the brake lever for 2 days
and they're ..... excellento
Old 16-Nov-2004, 10:11   #12
Twinfan Twinfan is offline
Twinfan's Avatar
Cheers again guys - I'll look into all this. As always, top info!
Old 16-Nov-2004, 10:19   #13
yeti yeti is offline
yeti's Avatar
TF, reckon you just needing to get used to a different feel. When I fitted an AP master cylinder to my 996 it felt really strange at first as I was having to pull the lever quite hard. Since changing the calipers to GP Brembo's, I have adjusted the ratio slightly and it all makes sense now, pull hard to start with, brakes start to bite then it's two fingers all the way.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:09.
