Old 04-Jan-2005, 23:26   #11
Of all the clutches I've replaced the springs on with stainless, I've had no problems whether they've been SBK, ST, M's, slippers or conventional.
The polished springs on the market tend to be within a gnats of the standard ones tension. I've also used some "natural finish" springs and these have appeared a little heavier.
When you say you've replaced the master as well as the slave, if the master is a Brembo radial, the bore on those is bigger than stock. This will further decrease the effort being offered by the slave cylinder.
IMO, you shouldn't worry too much. Get out and try it and see how it goes.
You could put a washer under the spring caps, but if you are getting slip, then I'd check the clutch plates and pack thickness first.
Increasing the pack thickness with a couple of thicker plain plates will increase the preload on the springs a little and is "technically" a better option than using washers..............c'mon it's a Ducati
Old 04-Jan-2005, 23:42   #12
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
nelly fitted some stainless springs for me in the summer.
I can hardly notice the difference, except round town with lots of clutch work then it seems to knacker the wrist a bit quicker... more wrist excercise needed I think!
no probs at all with slip.
Old 05-Jan-2005, 21:12   #13
DC DC is offline
DC's Avatar
Mood: Double 9, Single 6.
Cheers chaps, thnx for the replys. I best get out and ride the bike!!
DC
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 00:58.
