Old 08-Jan-2005, 16:13   #11
the phantom pieman the phantom pieman is offline
the phantom pieman's Avatar
Mood: Sort of shuffling along .....
Originally posted by RickyX
I drilled and tapped my swingarm for DP Hugger last week.
Make sure that you use a brand new drill and tap.
I centre punched the hole location after positioning the hugger, then used a 2mm dia "pilot" drill followed by a 5mm dia start drill. I then tapped with an M6 x 1.0mm pitch tap. All went well and hugger is snug as a bug and doesn't flap around like a flappy thing.
Better than bodging it with velcro or sealant!!!
R X
Your choice, obviously ...
But
a) It works
b) No-one sees it...
Old 08-Jan-2005, 16:32   #12
rcgbob44's Avatar
Velcro!, spose you`l be looking for a hitching rail next!
If you want to fasten the hugger to the swing arm don`t mess about, do it properly and drill it. It takes all of five minutes to do a good job.
Nuff said.
Old 08-Jan-2005, 16:57   #13
Walenut Walenut is offline
Mood: Erratic
Will the drill break through, as its in a rather substantial part of the swing arm?
Old 08-Jan-2005, 17:10   #14
Mood: Erratic
Hurry up I'm in the garage poised to drill it!!!!!!!!
Old 08-Jan-2005, 17:13   #15
Mood: Erratic
5mm!!!!!!!!
Old 08-Jan-2005, 17:21   #16
madmav madmav is offline
Bikes: 1098
madmav's Avatar
Mood: Chilled
just do it steve ! u know u want to
Old 08-Jan-2005, 17:23   #17
Mood: Erratic
Its done m8!
Old 08-Jan-2005, 17:52   #18
Mood: Erratic
Well it’s now done, drilled and tapped. I picked this method in the end because I had all the bits lying around, including a nice stainless cap head to stick in the hole, although drilling a hole in my nice unmolested swing arm didn’t exactly turn me on the result is a solid job. If any one else does this method the drill will not break through in the inside of the swing arm. I have drilled to a depth of about 13mm or more giving a 10mm depth of thread and as Ricky said used a centre punch, followed by a 2mm then a 5mm HSS drill, although mine weren’t new though, and tapped M6x1.0mm pitch thread. (This is the same as the other bolts that hold the chain guard on.
Old 08-Jan-2005, 18:02   #19
Mood: Erratic
The other thing I met to say was, I never bothered on my old 748 and the tyre rubber a hole through the hugger, mind you there is less clearance with a 180 any way.
Cheers all,
Steve
Old 08-Jan-2005, 18:07   #20
Bikes: 1098
madmav's Avatar
Mood: Chilled
Steve make sure you have the Axle in the right place in relation to the swing arm!
it does make a big difference
if you are not sure ring me !....keith
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 00:56.
