Old 30-Jan-2005, 20:14   #11
adam adam is offline
Mood: happy
I originally bought this kit for my 748R. when I p/x it for my 996R I asked them to transfer the PFMs onto the 996R. They phoned me to say they wouldnt fit. off set not right. Both bikes had ohlins. How does that work then?
So then Bold, the 748R does have machined backs on the forks, thats why they fitted that bike. How else do i solve the problem?
[Edited on 30-1-2005 by adam]
Old 30-Jan-2005, 20:25   #12
bolds bolds is offline
You can either get some 748/998R Ohlins or get your forks machined at the back of caliper mounts by 5mm or the other option is to get some PFM discs of standard type dish
Old 30-Jan-2005, 20:33   #13
Mood: happy
could the discs be spaced away from the wheel, or calipers away from the forks? which ever way round it is.
Old 30-Jan-2005, 20:37   #14
FiscusFish's Avatar
Originally posted by keefer
I had some 5mm shims made up by Yeti to put the calliper back to where it should be. and that's all you should need
Old 30-Jan-2005, 20:43   #15
Mood: happy
what about discs away from the wheel. Is this a safe modification?
Old 30-Jan-2005, 20:47   #16
The problem you have is that your 748R discs have a deeper dish than 996R (5mm) therefore the discs will be to wide and your calipers will be 5mm to far inwards and not to far out- which is what Yeti's spacers would rectify.
as stated before there is no spacing options only replacing fork legs/bottoms or maching bottoms or buying correct discs to suit
Old 30-Jan-2005, 20:53   #17
ericthered40's Avatar
Mood: renegade sexy racer
Why are P F M saying they are the same fittment code on their site ?
Old 30-Jan-2005, 21:12   #18
Mood: happy
Dont know mate
Old 30-Jan-2005, 22:18   #19
996R Ohlins fork leg inside of caliper mount
Old 30-Jan-2005, 22:19   #20
And 748/998R Ohlins inside of caliper mount
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:55.
