Old 31-Jan-2005, 19:01   #11
crash crash is offline
Originally posted by FiscusFish
Carb Icing.
Felt like it wanted to cut out or a spark plug had gone bad? Fairly nippy out but not freezing and a bit dampish? Bike felt OK with throttle wide open?
Slkoline Pro FST or other such stuff.
Darren
Yep - that pretty much describes it. I know I have suffered carb-icing before, but never back-fires.
What is Silkolene Pro FST ? An octane booster ?
I always use super-unleaded anyway (Shell Optimax)
Thanks to all for your advice.
Dave.
Old 01-Feb-2005, 03:50   #12
Bikes: ST4S
Mad Dog Bianchi's Avatar
Well, if you have eliminated the breather hose (do you use a tank bag that may slide forward and bend the hose at low speeds) and the carb icing problem, I would check the carb fittings. See if they are on nice and snug, with no air leaks around the mountings. I had similar problems and tightening up the mounts cleared them up.
93 750SS
Old 22-Feb-2005, 23:51   #13
Carb Icing.
Darren
Darren - tried Silkolene Pro FST - works a treat
Thanks for the advice mate.
Dave
Old 23-Feb-2005, 00:04   #14
Some good guys on here eh?
As an aside - I was surprised how much water was in my tank and and float bowls when last drained.
Happy riding - Frank
Old 23-Feb-2005, 00:19   #15
Frank, how did you discover this, and how did you drain it?
I know how to do this for a diesel engine () but never imagined it to be a problem on a bike.
Dave.
Old 23-Feb-2005, 00:40   #16
Two seperate occasions Dave....
Drained the Carbs the first winter I had the bike (there are drain screws on the float bowls and I ran hoses off them to collect the dregs).
and....last month I drained the tank to inspect for corrosion that I had seen previously.....I reckon there was about 50mls of water came out - surprised me.
Frank
Old 23-Feb-2005, 09:18   #17
ali ali is offline
ali's Avatar
Mood: Damp
Originally posted by crash
Help.
Rode to the Ally Pally show today, and my 1993 900ss (carb model obviously) was backfiring all over the place (on the over-run, and also on a neutral throttle at low revs).
I have never suffered this problem before. Also, low speed running is very rough, and she will barely tick-over at idle. Every time I stop at lights and pull the clutch in - it stalls.
Anyone got any clues please?
Funnily enough these are the exact symptoms my 600ss was showing last week. Finally traced it to a knackered coil on the back cylinder. Pinched one off my 900 and all's well (until the 900 finds out!).
Think I'll get some FST in just in case!
Ali
Old 23-Feb-2005, 12:32   #18
fil2 fil2 is offline
fil2's Avatar
Mood: is it still wet
Help.
Ali
exactly what i have a litre of at home now for just such an occasion.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:49.
