Old 07-Feb-2005, 23:13   #11
GsxrAge GsxrAge is offline
GsxrAge's Avatar
The mrs had not ridden for a year untill yesterday.
But we have had the bike for three years and she has always found it heavy.
It is harder than my 996.
Perhaps she needs to do more hand exercises
Old 14-Feb-2005, 00:00   #12
Gary T. Gary T. is offline
Gary T.'s Avatar
Mood: dazed and confused
I used to have a 1995 M600, so know exactly what that bitch of a clutch is like
No simple fix for this on early monsters, as the clutch slave is built into RHS engine case and your stuck with the M/cyl ratio too. One thing that does help a bit is fitting a span adjustable lever set, as the standard fixed levers are a bit of a stretch for short pinkies. Another possibility is fitting a braided steel line, which although not reducing the effort required may make the action shorter or more positive.
Other than that it's a swap to later monsters with the revised LHS clutch slave set-up, which can be upgraded as with 748/916/996 etc...
[Edited on 14-2-2005 by Gary T.]
Old 14-Feb-2005, 14:45   #13
With a lower-torque 600 I don't think you'll get any slippage (try it by accelerating in top gear) if you remove every other clutch spring. It'll give you half the clutch lever effort.
Old 14-Feb-2005, 18:11   #14
GsxrAge's Avatar
Cheers shazaam.
Might try that.
Old 20-Feb-2005, 18:31   #15
Gary T.'s Avatar
I think it will slip like a goodun with only three springs in it
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:02.
