Old 09-Feb-2005, 07:26   #11
May be this will help
Chris.
Old 09-Feb-2005, 09:57   #12
Imagine a 996 with 14/48 gearing!
I'm just about to change to 14/39 ...
Old 09-Feb-2005, 12:11   #13
smilo006 smilo006 is offline
smilo006's Avatar
Mood: I like my bike
Actually saw a bloke running 15 48 or 14 48.
Lasted half a track day before wrecking himself and the bike.
Old 09-Feb-2005, 12:34   #14
14/48
I think you would really struggle to keep the front wheel on the deck!
Old 09-Feb-2005, 19:47   #15
Delooney Delooney is offline
Delooney's Avatar
Mood: Just the one bike for me now
My 748s has standard sprockets. Under some serious throttle in 3rd it doesnt even raise an eye brow.
Me mates 995i Triumph has a reduced front sprocket and lifts up like a C90 with nitrous.
Does anyone recomend changing the front sprocket on me Duke ?
Delooney
Old 09-Feb-2005, 19:50   #16
Common consensus is that as the 748 comes standard with a 14th front that if you want to lower the gearing you should go up on the rear.
Old 09-Feb-2005, 19:57   #17
Delooney's Avatar
Is it common consensus that the rear mod is the way to go ?
Or should I just leave it standard ?
Delooney
Old 09-Feb-2005, 20:04   #18
Delooney
It's up to you really. If you're happy to sacrifice a little top end for more acceleration then go for it. For a 748 I would add teeth to the rear sprocket, go up 2 or 3 and you'll notice the difference I think. If you want a big difference add more but there are implications on your ride height so if you do it yourself make sure you measure your ride height before you start goofing around and set it back to that when you're done.
My 996 standard is 15/36 - I went to 14/36 and now I'm going to 14/39
I don't use the top end anywhere so I'd rather have the seat of the pants acceleration.
Old 09-Feb-2005, 20:42   #19
Rattler how did a 16 tooth front lengthen the wheelbase?? To me thats a larger than std sprocket which would shorten the length of the chain ....unless you fitted a longer chain!!?
I think 15/38 is a nice compromise on the 99*s
Old 09-Feb-2005, 20:54   #20
Sorry, my fault - too much sauce!!! I went one down on the front!! a 14t I think!!!
Tim
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:41.
