Old 23-Mar-2005, 13:25   #11
Red Steve Red Steve is offline
Just had a reply from the service manager at Ducati Bristol, and I quote:
"The so called recall in question is not a recall and is only for bikes that have a running problem from new. The valve springs are too weak and cause running problems which we don't have with your bike so don't worry."
I suppose if you have an ST3 you need to decide if you've got a running problem or not. Mine is fine as the dealer says, and it would appear that this issue is not an official recall problem.
Hope this helps
Old 23-Mar-2005, 13:33   #12
DUCMANs DUCMANs is offline
DUCMANs's Avatar
Hope this helps
Like I said, it is not a recall but a service bullitin and yes you have to decide for your self if your bike is suffering from bad idling and "on and off" reactions. But I would sure try to get both replaced....
regards, Jean
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:24.
