Alarms and Related Security
Old 27-Feb-2005, 18:19   #11
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
Try the plug/feed from the right hand handlebar switch cluster.
Andy
Old 27-Feb-2005, 18:23   #12
stu-st4 stu-st4 is offline
Mood: patiently waiting
That's a 4 pin plug
Old 27-Feb-2005, 20:09   #13
Rushjob's Avatar
Mood: :-)
I think there may be a 3 pin plug which controls part of the ignition / injection sytem...I don't have access to an ST4 wiring diagram, but the 996 one I have has it on that diagram as feeding the injector relays
This is a logical location for another circuit break to immobilise the bike.
Do you have the wiring diagram inthe back of your hand book?
If so, it shows the number of contacts in each plug inthe loom & you may be able to deduce the poisition it plugs into fromthat.
Failing that, give Nelly a ring tomorrow..
Andy
Old 27-Feb-2005, 20:31   #14
Thanks rushjob I will look at the wiring diagram if not I will ring Nelly, do you know his number,
Thanks, Stu
Old 27-Feb-2005, 20:47   #15
Rushjob's Avatar
Mood: :-)
01623 758877
Old 27-Feb-2005, 21:29   #16
Thanks Rushjob,
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:04.
