Old 12-Oct-2012, 07:42   #11
Originally Posted by bally71
at the moment its lid off with no filter.
i didn't expect to get any extra horsies .. just want to lose the weight and gain some space
Not the best of ideas, you really need a filter, it only takes one trip into the kitty litter for the engine to ingest gravel or any other foreign object to play havoc with your engine internals. Remove the lid, but leave a performance air filter in place.
Did a dyno run a few years ago on a 583 class B, very little gain in hp, less than 1bhp.
If weight saving is your main aim, look at other items, the battery is the biggest area to lose weight, trim the frame of excess bits, make sure your fairing is as light as it can be etc.
Old 12-Oct-2012, 10:24   #12
agree - some filter is needed and helped witrh power rather than reduce on my 583...not sure of difference on a 620 as didnt try it. But dyno man tried with pods v with airbox and set up with pods would have been much harder he said
Old 12-Oct-2012, 13:50   #13
bally71's Avatar
Mood: Inquisitive cat
ran my 800 for a year in minitwins with no filter
back to back dyno runs showed a 4 - 5 horse increase all through the curve without one
had a good classics set up in the w100 club .. always liked the look and sound of the open carbs
admitedly i'd be a little nervous just having the throttle bodies open to the atmosphere at least the airbox affords some protection
Old 12-Oct-2012, 14:09   #14
Did you have different maps done for both, or was it a case of adding the filter richened the mixture and lost 4 - 5 bhp
Old 12-Oct-2012, 14:38   #15
bally71's Avatar
had a custom map for both
Old 12-Oct-2012, 18:30   #16
yorkie yorkie is offline
Bikes: 900 Monster, 750 SS Cafe Racer
yorkie's Avatar
Cool
I fitted some of these to my 900ss engined Monster:
http://www.unifilter.com/online%20ca...universal.html
Got a nice induction roar as a pro!!
Yorkie
Old 13-Oct-2012, 11:03   #17
bally71's Avatar
Yorkie
looks just the ticket
hmmmm ... what about a couple of small air scoops with an in line filter?
Old 13-Oct-2012, 12:18   #18
I think AK tried ram air several years ago without any real success.
As my 620 uses the same size airbox, throttle bodies and injectors as my 1000SS I doubt there is much that is holding back the performance once the airbox lid is opened up.
As Andy Pike says a Plenum chamber is one of the best ways to go so as to create a large reservoir of still air for the engine to be able to draw on, so long as that air can be replaced as quickly if not quicker than the engine uses it then it should be able provide the desired air/fuel ratio through out the rev range and not be effected by speed
Old 13-Oct-2012, 12:44   #19
bally71's Avatar
ah but it's not just performance kev .. it's the joy of creating something different .. and something you can blame when your slower than everyone else
Old 13-Oct-2012, 12:50   #20
bally71's Avatar
does the airbox create a reservoir of still air? ..after all it's being constantly drawn
i can imagine with the trumpets in place you could expect the incoming air to be sucked in in a nice laminar fashion .. but with the top hacked off??
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:23.
