Old 05-Apr-2005, 22:31   #11
The996Master The996Master is offline
thanks guys
the go star racing site is very "in-depth"
I`m at rocky CSS on Monday, they may have a tech there.
Old 06-Apr-2005, 16:19   #12
psychlist's Avatar
Mood: Lucky? For some, maybe!
Its a setup
I'm organising a suspension setup session with Francis Williamson for Sussex DSC late April/Early May. If anybody else is interested in coming along please let me know.
Old 07-Apr-2005, 14:24   #13
Gary D Gary D is offline
Here's some good info.
http://www.section8superbike.com/tech.htm
Old 07-Apr-2005, 20:50   #14
Mr_S Mr_S is offline
Just remember that section 8's ride height settings are for mono subframes, if you've got a bip or bip subframe their ride height measurements too much....
Old 07-Apr-2005, 22:17   #15
doogalman's Avatar
Anyone have a figure for the ride height on a Biposto?? Just as a base- line.
Doogalman
Old 07-Apr-2005, 22:50   #16
Mine's at 570mm, and that's slightly higher than stock would be by about 5mm.
To set yourself a baseline to work from the ride height adjuster should be 261mm between eye centres (pain to measure on the bike)
This should give you a reference to start from. But take a look at this thread and get your name down for a ride height tool to do it properly
http://217.199.188.40/xmb/viewthread.php?tid=16584
[Edited on 7-4-2005 by Mr_S]
Old 07-Apr-2005, 23:39   #17
MARTIN H MARTIN H is offline
MARTIN H's Avatar
When I got my 996s a few years back Trevor Franklin had one on a long term test when he wrote for performance bike. He set the suspension up to suit his weight which is near enough the same as mine. I copied his settings exactly and the bike was 100% better. I will try to find the article (think its with the hundreds of bike and car mags in my loft) I remember it involved raising the rear ride height by quite a bit as I recall if I parked my bike next to another 996 it was noticably higher at the rear. I think he also ended up fitting a different rate spring. I cannot remember the exact settings but I remember my thinking went from being unsure if I had done the right thing buying the bike to knowing I had done the right thing after one good rideout.
Old 09-Apr-2005, 10:30   #18
haggizbasher haggizbasher is offline
Mood: Chilled
Check out this website....it'll give you something to work with. Carried out by Performance Bike....
http://www.mad-ducati.com/Technical/916Suspension.html
Old 09-Apr-2005, 21:43   #19
deej deej is offline
deej's Avatar
take it to someone who knows what their doing
ive just got back from louigimoto and he fiddeld with my rear shock and its awesome now
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 00:16.
