General Motorcycles only
Old 09-May-2005, 00:20   #11
Carbon749's Avatar
Mood: I own a flame thrower
Not an expert, but, when you have anything polished the first operation is to Mop the item. This is a course fabric (possibly calico) wheel with a course soap that will give a satin finish whilst buffing out deep scratches (and letters). At this point it will look really nice and race.
Normally the next stage would be to use a finer wheel and soap to polish to a mirror finish.
All that said, I'm assuming that the standard can is stainless steel .... if it's mild steel with a protective coating then any type of buffing etc will remove the coating and the can will go rusty
Old 09-May-2005, 00:22   #12
GsxrAge GsxrAge is offline
GsxrAge's Avatar
cant you change "not" and make it "hot" ?
Old 11-May-2005, 12:31   #13
swannymere's Avatar
Mood: High as a kite!
I have had an idea about how to cover the 'FOR RACING USE ONLY' stamp on my termi can (749).Does anyone know if it is possible to cover it with a line of weld and then repeat the process in the same location on the opposite side,so that it looks structural?I'm not sure if it would damage the can,but i'm sure you'll let me know
Old 11-May-2005, 12:53   #14
Gizmo Gizmo is offline
Mood: is it the weekend yet??
Can you polish it out of a titanium end can?? i'd think the ti is a little bit thinner than steel and am concerned it would leave a weak point on the can.
Old 11-May-2005, 13:21   #15
Simply stamp the word "NOT" in front !!!
Sorted
Old 11-May-2005, 13:31   #16
swannymere's Avatar
If only it was that simple
Old 28-May-2005, 10:34   #17
yorkshire pud yorkshire pud is offline
Mood: poon tang
take it to a polishers or buy a mop and some lea compond. it well polish out.
Old 28-May-2005, 10:56   #18
swannymere's Avatar
Thanks,i've bought one of those 'dremel'? multitool things which has polishing attachments,what sort of compound do i need?What is 'lea'?Any help appreciated.
Old 28-May-2005, 11:32   #19
Screwy Screwy is offline
Screwy's Avatar
You could try fine valve grinding paste if your using a dremel , Its similar to the paste they use on scurfing mops at most metal polishing shops .
Old 28-May-2005, 22:10   #20
swannymere's Avatar
Thanks for the info,what happened with the breakers?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:29.
