Old 20-Jan-2013, 19:38   #11
Epicycle were a bit cheaper than Ducati, although the Ducati ones did go to 12 degrees
06104/02
06104/04
06104/06
06104/08
06104/10
06104/12
Old 21-Jan-2013, 19:53   #12
bally71's Avatar
Mood: Inquisitive cat
When Epicycle were trading they were previously selling stepped keys in 2010
Stepped keys @ $ 38.00 :In steps of 2 degree, 4 degree, 6 degree, 8 degree, 10 degree, 10 degrees quates to 1/2 a tooth out, so as they can be fitted either way this gave all the scope required to set the timing accurately
I take it you do need the keys if you want to advance or retard
Old 21-Jan-2013, 20:28   #13
paynep's Avatar
Mood: Wet wet wet
As I understand it there's pros and cons for the different pulleys. The stock adjustable 620 ones are easier* (* = relative term) to alter and you don't need to buy offset keys, but the non-adjustable later 600/750 ones are lighter, which is supposed to be better.
I couldn't decide which is best so I have one of each........
Old 22-Jan-2013, 13:06   #14
batesy2 batesy2 is offline
Bikes: ducati 620ss racer,aprilia rsvr mille,husqavarna 125 crosser
Mood: easy going,love to laugh,fairly competetive
This is all very entertaining -) but no one has stated what the settings we are seeking actually are ie max opening of inlet at ? degrees
Please explain,the suspense is killing me
Batesy
Old 22-Jan-2013, 13:24   #15
yendor yendor is offline
Batesy
If you had the optimum settings & a super powerfull engine how many peps might you tell?.Trial,time,& lots of track time is the answer i think.
Old 22-Jan-2013, 15:02   #16
If you dont know either just say so x
Old 22-Jan-2013, 16:24   #17
dunlop0_1's Avatar
makes c**k all difference. Just ride smoother and brake later.
Old 22-Jan-2013, 16:39   #18
Whats an optimum setting?? I time mine differently to the well published settings. Other people may also do theirs differently also. As a start do it to the book but make sure both cylinders are the same, as often they are not.
No one is going to pass on their own settings which work for them and has taken seasons to develop.
Old 22-Jan-2013, 17:08   #19
bally71's Avatar
i'm not daft enough to think it will make me any faster
Old 22-Jan-2013, 17:46   #20
dunlop0_1's Avatar
there's a book for this.
must learn to read......
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:35.
