Old 20-May-2005, 10:22   #11
Gizmo Gizmo is offline
Mood: is it the weekend yet??
Originally posted by nathanhu
64kg spring ...... i had to go up to a 85 on mine ........
I only weigh 65 kg and the Ti termi can is quite a few kg lighter than the steel can. i think its a bit too light and am going to swap it for 68 - 70 ish i think, need to know how much 15mm of spring preload equates to in spring weight. I'd prefer to have spring at full extension so I can run more preload if I'm at a track day but want a soft road setup rest of time.
Old 20-May-2005, 10:27   #12
What you need is the Ohlins remote preload adjuster
Non of this C-Spanner nonsense, no scraping knuckles trying to get in around the pipes etc
Old 20-May-2005, 10:38   #13
Originally posted by HW
Any use to you?
http://www.section8superbike.com/749-999suspension.htm
yeah i read that and used it as a guide for ride height although quite why they say lower front when you can steepen head angle i'm not sure. Dropping forks through does make a hugh difference though. I'm always reluctant to accept preload and damping settings, i tend to ride on bumpy roads not a race track so need a more comfortable setting which is usually softer and with little rebound to stop it packing down as you go through a series of different size bumps.
The Ohlins website has some useful stuff.
The following pdf's cover most of it
Ohlins fork manual
Ohlins rear shock
Set up guide
Ohlins tuning
[Edited on 20-5-2005 by Gizmo]
Old 20-May-2005, 17:04   #14
COL595 COL595 is offline
Mood: Lascivious
Ducnow - Nothing in my 999R toolkit
Col.
Old 20-May-2005, 19:34   #15
Ducnow Ducnow is offline
Thank you all.
Yep, seems like it doesn't come with the bike
As for the settings..... i'm going to try section8's advice on preload set up.
Old 21-May-2005, 09:33   #16
butch890 butch890 is offline
Mood: Enjoying Togdom !
My baby R came with one.
Butch
Old 21-May-2005, 09:36   #17
Mind you its not much good as i can never find it,whoever thought of trying to attach velcro onto carbon fibre,tool kit spent most of its time in the belly pan!
Its now in the barn at home!
Butch
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:39.
