Old 23-May-2005, 08:29   #11
Mood: going for a ride...
Originally posted by keefer
well i wouldn't remove the sub frame but just undo the bottom two nuts and slacken of the top two then leaver it up, you can then access the cans.
firstly though remove the seat then tank so you can put your trick filter in
sound advice about the subframe . detach the seat part from the tank for clearance , 17mm bolt under in centre.
You don't remove the tank on 749/999 to fit the filters , it's top fairing off I'm afraid and then remove airtubes , 3 x 5mm allen screws , old filters out new filters in , re-fit airtubes and top fairing.
easiest was to fit ecu is remove battery , disconnect wire to front plug , sidestand and sensor , unbolt battery box housing and swing out towards rear of bike , ecu has 2 small bolts through from outside and then open the cam locks on the connector pins to remove , fit new ecu and reverse the procedure.
if it is a full system you are fitting , don't forget to fit the spacer kit to the r/h footrest mount for clearance.
...............have fun
Old 23-May-2005, 11:45   #12
Wylie1 Wylie1 is offline
Wylie1's Avatar
Originally posted by andyb
Now the air filters. Be very carefull with the bolts that hold the air tubes to the air box. Dont cross thread them!
......and if one of the bolts is already cross-threaded?? When I undid the bolts, one was loose and just spinning in it's thread. I've managed to get it out, but it looks like I'm going to have to re-tap it, unless anyone's got a better idea
Old 23-May-2005, 14:07   #13
swannymere's Avatar
Mood: High as a kite!
Threadlock and gaffer tape
Old 23-May-2005, 14:13   #14
Wylie1's Avatar
Ahhh....so it was you that last serviced my bike
Old 23-May-2005, 21:49   #15
swannymere's Avatar
Factory Trained
Old 29-May-2005, 22:44   #16
Wylie1's Avatar
Finally found the time to put it all back together.
Couple of questions though:-
In the de-cat'd pipe for the front pot, there is a threaded hole just after the joint with the manifold. What is it there for?
I've tried to get the bolt out of the old pipe to re-use, but it won't budge. Is it simply a case of finding a bolt the same size to block it off?
Old 29-May-2005, 23:04   #17
bolds bolds is offline
Its the take off for CO to set up fuel injection mixture
if you can find a bolt with a fine thread like the original any will do
try tapping the head of the old bung with a hammer (it crushes the copper washer) and you can usually remove it with your fingers
Old 30-May-2005, 08:41   #18
Don't use a bolt , the "plug" for the C02 sensor point is only the same depth as the boss it screws into , a bolt will protrude into the flow of the exhaust.
Get some "easit" or penetrating oil on the plug in the standard pipe for a while and then try removing it again , or go to your dealer and buy a new plug for your de-catted pipe.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:18.
