Old 24-May-2005, 00:11   #11
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
You can take the route Monstermob suggested or you can scrape off the major high points ( pips) and then unibound it all over twice. You can then get a plasterer in to bound coat it with bounding plaster and then scim it over with finish.
Old 24-May-2005, 00:13   #12
MARTIN H MARTIN H is offline
MARTIN H's Avatar
Its stuck very well and its in a matt finish.
Old 24-May-2005, 00:15   #13
ericthered40's Avatar
Mood: renegade sexy racer
thats the one
Old 24-May-2005, 00:16   #14
Jon Jon is offline
Jon's Avatar
What ever you do don't!!!!!!!!! lay that floor before you get the ceiling done. Its not the moisture that wll be your problem, but f any plaster gets onto the unprotected oak. It will send it black. You will end up with lots of little black spots all over the floor.
Old 24-May-2005, 00:19   #15
so right
Old 24-May-2005, 00:20   #16
Jon Jon is offline
Jon's Avatar
Old 24-May-2005, 00:26   #17
I have seen the spotty oak after sindrome meself you are spot on
Old 24-May-2005, 00:32   #18
Jon Jon is offline
Jon's Avatar
I thought you where takng the piz
[Edited on 23-5-2005 by Jon]
Old 24-May-2005, 00:32   #19
monstermob 998's Avatar
board over the artex with 3/8 plasterboard -just make sure you tack the nails into the ceiling joists not just the existing board -use galvanised plasterboard nails about 40mm long- then plaster with multifinish plaster cost around 3-400 quid for a 30msquare ceiliing around a fiver for a sheet of board -- youll need 11 sheets about four quid for a bag of plaster- youll need two or three -- a roll of scrim (for the joints) about a fiver for nails -- a stanley knife for cutting the board etc---- if you go the uni bond way then it will take longer to dry(more moisture to your boards) the boarding and plaster will be dry in a few hours-- dont forget to seal the plaster with a "mist " coat of emulsion before you paint it
oh and about a tenners worth of tea and coffee
[Edited on 23-5-2005 by monstermob 998]
Old 24-May-2005, 00:33   #20
MARTIN H's Avatar
Thanks I will keep the plaster well away from the oak! I would not have done it till I had it well and truly sealed (bonatech mega). Its only a couple of years ago that I layed 80 square metres of the stuff in my living room and passageway spent about 4 days sanding it to perfection only to go out to a neighbours barbecue and get horribly drunk and return home to admire my (unsealed) handiwork and spill a litre of red wine all over it! In my stupor I forgot to let my very large English Mastiff out for his toilet duties that night and he repaid me by finding his way through the barricade I had erected to keep him of the floor and took a very large wet dump bang in the middle of the floor.
I had to sand about another mm of the entire floor and can still remember the worst smell ever everytime the floor sander past over that particular section.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:57.
