Old 01-Jun-2005, 12:09   #11
misterpink misterpink is offline
Bikes: multistrada, 748R/916
misterpink's Avatar
Mood: one very coool cat!
hey mate - looks like you are my double same location/bike etc - spooky. my 2p-worth, am on my second 748E and have tried the 748R - it is the BEST, if you like 748's then it is really the top dog and i am still tempted to get one, in my case i use my bike everyday to commute, pick wife up from work, weekend trips, meetings out of london etc etc and the 748R is a perfect "sports" bike (track/weekends) but day-in/day-out....not to sure i could subject it to that abuse- however i have just bought another bike(for commuting) so i might change.
Old 01-Jun-2005, 12:46   #12
gunforhire gunforhire is offline
gunforhire's Avatar
Mood: #73 Class A newbie: I'm fitting seatbelts!
pretty much the same boat, yeah!
I'm in Highgate.
Sold the 748E - wasn't fast enough, and a R6 setup for Roadstock (wasn't a twin!).
Old 01-Jun-2005, 12:56   #13
Mr_S Mr_S is offline
don't you get ohlins at both ends with the R as well?
Old 01-Jun-2005, 12:58   #14
Yep! should get an Ohlins damper to if the factory has them in
Old 01-Jun-2005, 13:56   #15
desmojen desmojen is offline
Mood: DOH!
Depends what year you get, my 2000 model had no Ohlins at all, but to be honest, it doesn't need it.
I changed the rear to a race spec Ohlins last year (not oe stuff) and whilst the difference was noticeable it was not earth shattering. The forks are also Showa with Tin stanchions and are superb. I have fitted Ohlins springs as the originals were too firm, and I have to say the forks are excellent, I certainly won't be rushing out to buy Ohlins replacements!
[Edited on 1-6-2005 by desmojen]
Old 01-Jun-2005, 18:02   #16
Gaz 748's Avatar
I have a 02 748R (748S before) and I LOVE it, being quite light and + 3 teeth on the rear sprocket, it absolutely flies and you can use 99 % of the power on the road, they love to rev.
Old 01-Jun-2005, 18:17   #17
gunforhire's Avatar
mmmm....
all these ex-S owners now with R's!
Gaz, was your S one of the pre-2000 models? Just trying to understand why so many would have left 'em.
Old 01-Jun-2005, 18:48   #18
Gaz 748's Avatar
It was a 97 one of the first single seat S models, a good bike ( my mate bought it, still running well ) but the R is that much better, the engine spins up a lot better, it has a FIM chip fitted and runs very well, slight flat spot about 3,000 rpm but it runs well low down then takes off at 6,000 all the way to 10,000 +
Old 01-Jun-2005, 19:01   #19
Ericsson Ericsson is offline
A few more differences:
- Thinner walled CrMo frame with space for deeper airbox
- A bit lighter wheels.
- Shower injection
- Lighter crankshaft
- Lighter flywheel
- Different heads with larger valves 36mm/30mm and R-cams
- Higher compression pistons
Same computer though 1.6.
Old 01-Jun-2005, 19:07   #20
L3OONY L3OONY is offline
Mood: Mildly reckless...
...and the best bit of all?
It says "748R" on the side!
Worth an extra 10 bhp all day long!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:18.
