General Motorcycles only
Old 11-Jun-2005, 22:37   #11
hogfisch hogfisch is offline
Mood: dooM
I'd go for the torx method as well. Try and tap one in that is slightly bigger than the hex hole and hoepfully it will cut into the hole and allow you to turn it. Strange because I had exactly the same problem with my 748 today when trying to remove an exhaust hanger!
Old 11-Jun-2005, 22:50   #12
khu996 khu996 is offline
khu996's Avatar
Cheers lads. Will give the torx method a go.
Swannymere, where did you get the workshop manual from, and is it any good?
Old 11-Jun-2005, 23:32   #13
swannymere's Avatar
Mood: High as a kite!
Ducati dealer,£55,not cheap,but will probably pay for itself
[Edited on 11-6-2005 by swannymere]
Old 11-Jun-2005, 23:33   #14
YMFB YMFB is offline
YMFB's Avatar
I rounded off the inside hex of a bolt tonight luckily on the bracket that holds the pannier frame on. I removed it together with the A bracket that it was bolted to drilled a small hole right through the bolt then used a stud extractor. I was relieved to see the little bar steward come out. I would like to thank 3X for using about 300 million newton metres to tighten up such a poxy small screw. Good luck, Im sure Halfords sell stud extractors.
Old 12-Jun-2005, 23:47   #15
crash crash is offline
Had this happen to a sump plug - right ******* to get out. The only thing that touched it was a set of extractors from Snap-on tools. Very expensive, but I have used them countless times on Ducati cheese screws, and always with success.
When using extractors, you can also try using a plumbers freeze spray to make the offending bolt contract and loosen.
Good luck
Dave.
Old 13-Jun-2005, 13:54   #16
Paul996 Paul996 is offline
Bikes: S4R
Paul996's Avatar
Mood: Ready for Summer
You can also use a pin punch that is larger than the head of the bolt. Hold the punch over the head of the damaged screw and hit with large hammer. This will get the shape of the hex back (if not too badly rounded). Then use an impact screwdriver with a hex bit.
Has worked for me in the past.
Good quality extractor are good tools as well.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:18.
