Old 16-Jun-2005, 09:17   #11
uncledunnie uncledunnie is offline
just checked the site again myself after this jiggled my DD scheming mind
http://www.fuelinmoto.com.au/
says you can isolate the imobiliser no probs
Old 16-Jun-2005, 10:05   #12
Lee1980 Lee1980 is offline
Bikes: Xdaivel
Lee1980's Avatar
Mood: Xdiavel..awesome!!
Hi Simon I have seen ur second post on the DML great description of the work done very long to
Sounds great and the pics look great love the ohlins forks and radials to i want, want!!
Old 16-Jun-2005, 10:38   #13
marchesini marchesini is offline
Originally posted by uncledunnie
just a thought,
extension of the 999 association, once i realised the DP ECU I fitted was poop and in prior to having the PC3 fitted I explored the other ECU solutions, which were Corse ECU or FIM ECU, but since the FIM ECU wasn't available at the time and the Corse item was silly money I went PC3 route.
I don't actually do the work on my bike, I just give out the credit card numbers so apologies in advance for my idiotic questions. I have at present two different ECU's (the standard and the race one that came with the termis) and a PCIII. I believe that the race ECU is fitted along with the PCIII - this runs pretty well. To clarify, do I then need to buy another FIM ECU in order to bypass the immobiliser then - just plug this in and then you are good to go? I always thought the PCIII was a replacement for the ECU or do you still have to have the ECU inplace for immobiliser purposes - the PCIII's sole purpose is just to adjust the bike's fuelling etc. Am I correct in this thinking?
simon
Old 16-Jun-2005, 11:14   #14
The "race" one that came with the termi's will not be "race" in the factory Corse sense but a Ducati Peformance part with different settings to the base ECU supplied with the bike.
The PC3 is used as an easier way to alter the fueling, since the DP ECU is not readily hackable and adjustable. So people buy a PC3, stick it on and it overides the ECU on the bike in respect of fueling, it does not replace it.
The FIM ECU replaces the DP (or standard) ECU and is fully programmable which means you can then remove the PC3 (in your case) as all the fueling adjustments you need can be made via the FIM ECU.
The FIM ECU then allows you carry out other mods to the systems on the bike, ie increase the rev limit, bypass the immobilser and others as descibed on FIM's web site.
I would imagine the FIM ECU comes with a fuel map you can use and you can obtain other maps if you wish but it would really need to be remapped on a dyno (so it is specific for your bike) if you wanted the best from it.
So, if anyone else is thinking of changing zorsts on a later model Ducati with the ECU type brain - don't buy the DP ECU either buy a PC3 or if you want more features just buy an FIM ECU.
Old 16-Jun-2005, 11:55   #15
HW HW is offline
Good info .. thanks for that. I had been puzzling over the same issues.
Old 16-Jun-2005, 22:19   #16
Good news and bad news
Well, the good news is that if my bike was ever stolen, it would be near impossible to bypass the immobiliser and other electronic gubbins hidden about the bike.
Which means that the bad news is all I have found are dead ends.
Neil at Sigma said that although the FIM chip would bypass the immobiliser, the bike would still not work as there are a load of other sensors hidden in the clocks that need to be operative in order to start the bike.
John Hackett (Richard Hackett to be precise), said that anything can be done given time but to his knowledge it hadn't been done as yet. They had done a few 999's with Magnetti Marelli dashes but none with the Translogic version. It appears that Magnetti Marelli are working on something but who knows when that will appear? I am reluctant to hand my bike over as a guinea pig - I want it back on the road.
Finally, I phoned a good friend who installs bike alarms and immobilisers who through his contacts then got referred back to John Hackett. So it seems I have hit a brick wall with theis race dash idea.
As a last resort, I'll e-mail FIM and see if they have actually disabled a 999/S4R dash and got the bike to run. It seems that they are my last avenue to try so I'll post how I get on. I am not too hopeful though.
Best regards all
simon
Old 17-Jun-2005, 07:15   #17
Ducman851 Ducman851 is offline
Mood: Just Ducky
While I dont have a Translogic dash on my M800. I do however have an FIM ECU and a SPA Technologies Tach fitted. Once the stock ECU is gone the bike will start and run just fine I pulled power and ground for the Tach from the factory harness. Tach signall from the harness as well. I even have an oil temp set up but had to run the propriatary wiring from the tach to the sensor that came with it.
The Immobilizer system on the newer Monsters (early S4s excluded) marry the ECU, Gauges and Keys together once they are programmed. Its a onetime deal. The early S4s were able to swap ECUs back and forth and just reprogram the Immobilizer function.
Your best bet is to get the FIM unit and you can then wire in anything you want.
Old 18-Jun-2005, 00:48   #18
So your M800 uses the exact same immobiliser that comes on the S4R? If so, then there is hope. Do you still have the standard clocks fitted and if so did you try to run it without the clocks fitted?
Pics please if you have them.
simon
PS. How much are the FIM units over there. I have a friend who is visiting from San Francisco in a couple of weeks so if this the way to go, maybe I can take advantage of the exchange rates.
[Edited on 17-6-2005 by marchesini]
Old 18-Jun-2005, 06:25   #19
Mood: Just Ducky
simon
With the FIM unit installed I can start and run it wih no gauges at all. No so with the OEM ECU, they dont run without them.
Heres a shot of my dash.
It goes to this:
The FIM units are about $700 US
Old 18-Jun-2005, 10:48   #20
Don't know if you already have but you should take a look over on the UK Monster Owners Club. If meets and banter is your sort of thing, they are well worth a look.
www.ukmonster.co.uk
take care
simon
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 04:12.
