Old 06-Jul-2005, 20:26   #11
748IOM 748IOM is offline
Mood: Yellow!!
Can you not get Ducati UK to replace them?
I think it's their responsibility after all if the parts aren't up to the job.
Old 06-Jul-2005, 20:27   #12
Dibble
Originally posted by TP
Ahh .. now I remember where I've seen those heads before.
indeed
Old 06-Jul-2005, 22:26   #13
Mr_S Mr_S is offline
I bought a set of heads barrels and pistons from a bike that had it's bottom end destroyed after only 1500 miles.
My original plan was to swap the heads completely after a bit of re-working, however they're not a straight swap between the later 748 and the earlier, so I stripped it for rockers. I had to replace all of mine at 16K (in Feb), and paid less than £200 for the heads etc so it made sense to me, and the heads came from a very late model 748. The rockers that came out of the new heads looked exactly as they should with no signs of imminent failure, and that's as good as I can expect for £200.
Whilst it was stripped I had the whole top end refurbished, which I couldn't have afforded had I needed to replace all the rockers at full price.
MBP do an exchange service for replating at $45 each, and you're probably looking at a 4 week turnaround since they have to cross the atlantic twice. I think MegaCycle charge around $80 per rocker but they grind down and build up with a harder material, again delivery time's the issues
On a personal note, I always feel DukeDemon's prices are a little too rich for used parts.
Old 06-Jul-2005, 23:48   #14
Gav748sp Gav748sp is offline
Mood: Updating The Formula!
You COULD buy rockers from the USA... over there Ducati North America sell them for $45 ..infact no sorry they recently went up in price to $54
So pretty much you get three for the price of one, here in the good old UK!!
Gav
Old 07-Jul-2005, 00:29   #15
neil748r neil748r is offline
Erse biscuit!
dukess1999 - Iain - sound familiar?
Put down the crack pipe and walk away!!!
Old 07-Jul-2005, 12:13   #16
sheeny748 sheeny748 is offline
sorry to har you need six. it happens to us all at some time. out of interest are they all openers or are any closers damaged? i took a different route, when i found out the cost of new rockers and nearly fell over! i read up on the subject ,every body told me that ducati outsourced the plating in 96-97 so i looked around and found a pair of heads with a 95 date stamp, paid a lot of money for them i might add. but worked out the same as the five new ones i needed. the rockers had done 6,500 miles and were in as new condition, i also got spare cams,valves, shims. i checked them again recently, paranoia creeping in ! and they are still as new. maybe this is the way to go with your problem. the chroming does look better quality on the 95 rockers. if you need any closers,i might be able to help you out.
Old 07-Jul-2005, 14:37   #17
mikesps mikesps is offline
I had three openers worn at about 2000 miles on my SPS. Both horizontal openers and the vertical opener further from the oil feed.
Despite a lot of wear they were replated by MBP for USD 45 each. Took a while to get them back, but I think Guy was ill at the time. I would recommend using him, since the plating he has done is supposed to be tougher than even the latest Ducati attempts.
Mike
Old 07-Jul-2005, 17:01   #18
Thanks for all the answers - Gav, I tried Section 8 but they didn't have 3 of the openers in stock. I'll try some of the other Yankee shops.
Sheeny, they were 5 openers and 1 closer. My 748 is '95 but it has SPS heads which were fitted a fair bit later. I think I've got the closer sorted out but thanks for the offer.
Old 07-Jul-2005, 20:39   #19
Nattyboy Nattyboy is offline
Nattyboy's Avatar
Mood: Back down to 3 :>(
Ive got a selection of brand new genuine rockers..U2U me and ill see if I can help..part numbers would be helpful mate..
Nat
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:25.
