Old 09-Jul-2005, 21:45   #11
Jasper Jasper is offline
Jasper's Avatar
Old 09-Jul-2005, 21:45   #12
Jasper's Avatar
4
Old 09-Jul-2005, 21:45   #13
Jasper's Avatar
5
Old 09-Jul-2005, 21:53   #14
sparkin sparkin is offline
sparkin's Avatar
Thanks mate,did you swap to a single brake hose from the master cylinder then split it under the yoke,or run twin lines like the standard set up?Banjo switch for brake light?
Now changing to radial levers so any advice welcome.Where did you get the "lower" carbon dash from??
Old 09-Jul-2005, 22:05   #15
Jasper's Avatar
hi,
two lines from master cylinder,banjo brake switch.Are you doing the clutch as well?That opens up an horrendous can of worms!!Drop me an e-mail and i will go though the clutch bit!
You can get them here:
http://www.diopa.com/shop/shop.html
[Edited on 10-7-2005 by Jasper]
Old 10-Jul-2005, 11:18   #16
sparkin's Avatar
Are the bar tubes longer than standard,ie give you more leaverage?
Old 10-Jul-2005, 11:26   #17
Jasper's Avatar
It they are it is not by very much.You can have a look at TA4 if you haven't done it by then.
Old 10-Jul-2005, 15:26   #18
alan_db alan_db is offline
Link to my original post showing bike with alloy clip ons.
Dont know much about them as they came on bike when I bought it.
http://www.ducatisportingclub.com/xm....php?tid=20346
Alan...
PS. where'd everyone get the carbon dash & covers from. Look real nice
Old 19-Jul-2005, 14:41   #19
yellow916 yellow916 is offline
Sparkin, Jasper
Which is the "original" front brake line configuration - one or two pipes from the master cylinder? My SP3 has a single pipe which splits above the front hugger, but I need to replace the horrible red/blue alloy fittings with stainless, and I want to use the original pattern (unless the other one is much better?). If I decide to change to two pipes, are they readily available "off the shelf" or do I need dimensions etc?
Andrew
Old 19-Jul-2005, 19:51   #20
Jasper's Avatar
Mine was a single line that then split into two.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:32.
