Old 25-Aug-2005, 22:44   #11
MrWestys748 MrWestys748 is offline
So can you fit 916 50mm throttle bodies on a 748bp then....?
Old 25-Aug-2005, 23:27   #12
keefer keefer is offline
keefer's Avatar
yep but you would want some dyno time to make the most of it
Old 26-Aug-2005, 00:04   #13
Mr_S Mr_S is offline
And the gains are probably not worth it, unless you change the cams, compression, valve timing etc at the same time.
Old 07-Sep-2005, 21:15   #14
DC DC is offline
DC's Avatar
Mood: Double 9, Single 6.
Originally posted by skidlids
They should be OK the 916 and 996 both have 50mm throttle bodies as standard.
Better option could be a 748R shower injector setup which uses 54mm throttle bodies.
[Edited on 18-8-2005 by skidlids]
Tell me more about this option.
For example, does the 54 mm shower injectors need the ECU and wiring loom or can it be spliced to a 748/996 loom.
I expect that the inlet rubbers would have to be the ones that are fitted to the 54 mm bodies?
Would I have to run the R type larger air box to make it worth it?
Cheers skidlids.
I will have to say hello next time you are at the FOXs cafe. I can pick your brains then for info.
DC
Old 07-Sep-2005, 21:22   #15
keefer's Avatar
you would need a different ECU and loom.
the twin injectors on the 996 both work at the same time.
the shower set up on the R's work separately and the 996 ECU cant do this.
with regard to the air box I believe you would also need the R's air box as yes its larger. but there is also the need to supply the fuel to the shower injector which there is no provision for on the standard box.
Allot of hassle for little gain IMO.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:59.
