Old 22-Aug-2005, 17:12   #11
guest1 guest1 is offline
Originally posted by antonye
Yes, you need to check your PIR sensors as some are able to distinguish between a cat and a human, so will trigger for one and not the other.
If you don't have the right ones it should be a simple replacement job.
Hmmm, simple replacement it should be, but you would still need to lower the PIR to a level of say 1400mm AFFL, which means you'll have alarm cable coming down the wall.
Not sure on the "pet distingiushing" PIRs, but if the cat moves fast enough then I presume it's signature could be mistaken for a larger object and hence set the alarm off.
I've only ever seen one cat friendly alarm in a house with two cats, and that was where there was no PIR's and all window and door contacts.
Old 22-Aug-2005, 22:40   #12
Delooney Delooney is offline
Delooney's Avatar
Mood: Just the one bike for me now
We too have cats.
Most alarms now have zoning.
Each night I 'part set' the system disarming all the sensors except the contact switches on the front and rear door and the garage PIR.
Peace of mind...
Delooney
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:00.
