Old 24-Aug-2005, 21:50   #11
m1keyp m1keyp is offline
Simon
Keefers link shows the clutch needing held to loosen/tighten the alternator nut.
I found the vise grip type clutch holding tool that they used in the Haynes manual is made in the states with a UK Distributor Motion Pro part number 08-0008
Heres the website http://www.motionpro.com/Docs/servicetools_3.html
And this lot sell them in the UK, around £ 22.00 inc postage, it works well and the company below delivered next day
Allen's Performance R&D
Unit B9, Moorbridge Road
Bingham, Nottingham NG13-8GG
Phone: 011-44-1949-836-733
Fax: 011-44-1949-836-734
Old 24-Aug-2005, 21:59   #12
DSC Member simonducati simonducati is offline
Bikes: Had 748,749, 848 and now a 1199 Panigale
simonducati's Avatar
Mood: Living the dream.
Originally posted by m1keyp
Simon
good man il have one of them, but its not the Clutch side it the other side of the engine mate. Thanks
Old 24-Aug-2005, 22:01   #13
keefer keefer is offline
keefer's Avatar
dude you need to hold the clutch to undo/tighten the nut
Old 24-Aug-2005, 22:05   #14
I got it off and it look all good, I had to tap it off. I cant see no damage at the moment, so it mite just need tightening up. Back in a bit.
Old 24-Aug-2005, 22:09   #15
keefer's Avatar
once you have put it all back together (without cranck cover on) you can jab the starter button to see if the sprag clutch is holding. don't let in run though. remove the fuel pump loop so it wont prime.
[Edited on 24-8-2005 by keefer]
Old 24-Aug-2005, 22:13   #16
phil_h phil_h is offline
phil_h's Avatar
Beware the starter clutch though.
When it starts to go wrong it makes a sort of screech when you are starting. This noise may be disguised by a chattering if the real problem is that your battery is too clapped to run the starter.
Either way, when you start to get wear in the starter (sprag) clutch, it means taking everything apart again. Oh and if a sprag clutch jams, as they can when they wear cos theyve been used with knacked batteries, they can drop nice little bits of metal into your engine.
From memory, the haynes manual doesnt say much, but the 4v service notes tell you all about it.
Old 24-Aug-2005, 22:46   #17
ok. The gear from the flywheel goes freely one way but not the other, is that normal ?
Old 24-Aug-2005, 22:48   #18
in the starter clutch
Old 24-Aug-2005, 22:50   #19
keefer's Avatar
that's how the sprag clutch works.
engages when trying to start then spins free when running.
Old 24-Aug-2005, 22:54   #20
ok i get it, thank for your help, and il let you no how it goes tomorrow
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:19.
