Old 30-Aug-2005, 12:37   #11
DSC Member AK AK is offline
AK's Avatar
sounds my kinda guy!!
hangover, champagne......
Old 31-Aug-2005, 01:11   #12
Allstarbiker592 Allstarbiker592 is offline
North Carolina; I have been riding BMW with drive shaft soooo how often do you have to lubbricate the chain and with what is best and what is the correct tire pressure for the M1000S?
Old 31-Aug-2005, 14:27   #13
sparkin sparkin is offline
sparkin's Avatar
Wurth drylube for your chain mate,tyre pressures I would imagine the norm, 32front 36rear.Stand to be corrected tho.
Now that`s the tedious stuff out of the way I`ll have two pints(Did give you two answers ) of downpour and a packet of pork scratchings my American freind.
Old 01-Sep-2005, 07:29   #14
Yep,a dry chain lube is best,like Wurth or Putoline ceramic (yes really!)
You dont need to apply much lube,just give it a squirt every 250 miles or so.Modern o-ring chains have the links greased and sealed from new and require very little maintainance.Just keep it adjusted correctly,a gentle lube across the rollers and it should be ok for around 10-12k miles.
Its a good idea NOT to over lube the chain as dirt and dust from the road can stick to the lube and act as grinding paste!
The chain should also be cleaned from time to time.Use parrafin,(kerosene,to those on the other side of the pond!) and not WD40 as it can damage the o-rings.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:43.
