Old 13-Sep-2005, 12:16   #11
Originally posted by JPM
Centre hub on my Bucci doesn't move to be honest, sure it's torqued up?
Ah thank god sense at last.
Ive got a little end float on the centre hub, (when plates removed) new spring and torqued nut! Almost like the spring isnt strong enough, although i know thats not the case!
Old 13-Sep-2005, 18:33   #12
adam adam is offline
Mood: happy
give it a clout.
Old 13-Sep-2005, 18:39   #13
I guess at a push I might be able to do the same with mine, you have to remember the only thing holding the hub securely in place is the force of the spider spring
Old 13-Sep-2005, 19:52   #14
When I had the slipper moved from the 996 to the 998 on the weekend I needed a new spider spring because it had flattened out a bit.
Old 13-Sep-2005, 22:27   #15
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
I might be wrong but I've dropped the bike into first a coupe of times and locked the back wheel. I noticed that I had more than the usual play in the center hub. I think what might have happend was that the hub rode all the way up the ramp, further than was originally intended? I just bent the arms back on the spider spring and put it back together until I could get a new one. I still have it as a spare
[Edited on 13-9-2005 by Jon]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:23.
