Old 25-Sep-2005, 12:47   #1
Tonio600 Tonio600 is offline
Tonio600's Avatar
Mood: What a wonderful world.
don't say that, I just wanted Skid's confirmation cause he's using a Rollcentre laptimer and I was not sure you were.
What dos that mean changing them for bananas? I'm not hungry mate
Old 25-Sep-2005, 12:52   #2
domski's Avatar
Are you thinking of changing them for tops that have adjuster on them?
If so, you can't do that.
The forks must remain standard.
All you can do is get the insides changed - springs/oil/shims etc.
Old 25-Sep-2005, 13:14   #3
Tonio600's Avatar
Message original : domski
That was my idea. I found some very cheap tops with adjusters.
[Edité le 25-9-2005 par Tonio600]
Old 25-Sep-2005, 14:41   #4
Yep Sorry Tonio, Dom is not telling porkys, you are only allowed to play with the fork internals, so any additional preload you may want has to be done with internal spacers.
Old 25-Sep-2005, 17:38   #5
ali ali is offline
ali's Avatar
Mood: Damp
Hi Tonio,
The best shock to go for if you can't afford an ohlins would be a showa from a 900SS/900SSie. It'd definitely need re-valving/springing for your weight, but it's a good shock. You can always keep an eye on ebay.de, that's where I picked up my NCR shock, and I've seen a few White Power shocks on there for good money.
Cheers,
Ali
Old 25-Sep-2005, 17:51   #6
Tonio600's Avatar
Cheers Ali, sounds good. What's the main difference with the one fitted on the 620? Isn't it a showa as well?
Old 25-Sep-2005, 17:54   #7
I thought it was a Sachs unit?
Hrmm ... I'll check.
Old 25-Sep-2005, 17:58   #8
Rear suspension - Progressive cantilever linkage with fully adjustable Sachs monoshoshock. Steel swingarm
Old 25-Sep-2005, 18:18   #9
Tonio600's Avatar
this one seen on Ebay was fitted on a 900 SSie but it looks exactly the same than mine, so it's not what I'm looking for?
http://cgi.ebay.co.uk/DUCATI-750SS-9...QQcmdZViewItem
Old 26-Sep-2005, 09:46   #10
Tonio600's Avatar
Ali, what's a good price for a Showa rear shock absorber? I've found 2, one at £80 and I'm waiting for the other one's price.
Tonio.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:32.
