Old 09-Oct-2005, 23:28   #11
DucatiRoss DucatiRoss is offline
I never manage to take the fairing off without losing something ! It'll never go back together Rob !
Old 10-Oct-2005, 15:21   #12
OOeeeeerrr!
Old 11-Oct-2005, 06:07   #13
loony888 loony888 is offline
Mood: sensational!!
that's not an original 888 engine, what capacity is it? why did you change it? and what's being done now?
Old 11-Oct-2005, 08:20   #14
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
It's an ST4s engine so, 996cc. I always had plans to replicate the SP pawerband and the original crankcases are a bit weak. The ST4s has some of the best, in fact, if you order a spare set for your 888, it's what Ducati would supply.
Done now, Cosworth hi comp pistions, arrow Ti rod, full balance, 431 inlets and G exhausts, STM cam pulleys, probalbly new clutch bits, maybe a look at the heads, maybe a different set of gear ratios, a load of power grease and off we go to "Big Grin" city.
Rgds, Rob
Old 11-Oct-2005, 12:37   #15
Mood: sensational!!
thanks for letting me grill you
how do you like the cams?
i have just bought a set of sps cams to go in mine with omega pistoms and 34mm and 30mm valves.
Old 11-Oct-2005, 14:20   #16
Sut888 Sut888 is offline
Mood: yes
Rob,
What gear box ratios do you currently have?.
A different set of gear ratios makes a huge improvement over the standard Strada box. When my Strada cases had to come apart (Crank case centre gasket split) I had a 749R box fitted, it all goes in exept for the Counter shaft. This is too long , presumably to give the chain clearance for a wider rear wheel / tyre combo on the 749R. but every thing assemblies onto the original T8 shaft. I assume any 748/749 gear box would go in, and this gives you the same ratios as an SP5. I dont mean to keep banging on about it but the bikes performance with this box is incredible, you lose that huge leap up into sixth. In fact you lose the high sixth completely, as the 748/749 sixth gives the same ratio as the original Strada fifth gear.
The other engine mods sound very interesting.
Rgds, Ian.
Old 11-Oct-2005, 19:45   #17
sparkin sparkin is offline
sparkin's Avatar
Originally posted by Jools
OOeeeeerrr!
You do realise thats the compulsory winter rebuild proceedure for an 888 Jools,I expect you to follow the same lnow you have one
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 04:49.
