Old 11-Nov-2005, 23:19   #11
HUNT749 HUNT749 is offline
Will defo change tank just for piece of mind....had the pins out just to see what is under them luckly came out easy...will get new hose clips just to be on the safe side ... will be in touch if no joy in the morning....
Oh just fitted new bling carbon fibre sprocket cover (vented) and heel plates (look nice next to the sps type heat shield)...now what else can i find on fleabay
simon
Old 12-Nov-2005, 23:00   #12
Well had the tank pressure tested today at velocie (after i told them how to do it )...there a pin hole were a crack is forming on the top of the tank where it starts to bend if that makes sense ...
They have ordered me one (vor should be here weds so they say .)
Also asked them about a clutch cylinder overhaul kit as mine is starting to weep but they have stopped doing them but if you contact a brembo dealer they said they can still get them......
or should i buy a new cylinder
Simon
Old 12-Nov-2005, 23:42   #13
You can't get service kits for any of the road brembo gear anymore. You have to replace the whole unit.
Are you talking about the master cylinder (handlebar) or slave cylinder (engine casing)???
If it's the slave, Evoluzione do a good repair kit that doesn't leak.
Old 12-Nov-2005, 23:49   #14
Yes its the slave cylinder ..slight weep ,only a little but its enough...
simon
[Edited on 12-11-2005 by HUNT749]
Old 12-Nov-2005, 23:52   #15
The slave isn't Brembo. It's a Ducati part.
The Evo' pistons are pretty good bits of kit. £18 and a hour at most to fit. You can buy a replacement piston from Ducati but it'll cost about £25 and it'll leak again
Old 13-Nov-2005, 00:01   #16
cheers look like evos the way to go..do you have a www.etc for them
cheers Simon
ps did give the bike a damn good clean as its all striped
Old 13-Nov-2005, 22:14   #17
Dibble
cheers Simon
ha ha ha, I love this .... Nelly owns and runs Cornerspeed .... www.cornerspeed.co.uk ring him tomorrow and he will organise you either an Evo piston for the standard slave or if you want some bling get a Cornerspeed uprated Slave, Nelly is my 1st call for all things Ducati ....
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 00:23.
