Old 13-Aug-2003, 11:03   #11
Totto Totto is offline
I had a road tyre do this ( BT56s) on my ZX6r about two years ago (on a track day), again the concensous was that the track was hot /tyres pressures wrong !
Spoke to my tyre dealer & he said the pressure was prob wrong on the day !
[Edited on 13-8-2003 by Totto]
Old 15-Aug-2003, 22:38   #12
scuffy scuffy is offline
Mood: Ready for another V-twin
My rear 208GP* looks worse
Caused by to much heat from the engine,heating up the rear shock so losing all the damping.
The extra heat from the engine was caused by the crank shells deciding to have a look around the inside of the crank cases
Old 17-Aug-2003, 08:35   #13
Mood: aving a laff
Ouch....
Sounds expensive Scuffy.
Old 22-Aug-2003, 18:48   #14
Did you use tyre warmers???, as it looks like cold tear, happens with warm tyres on a cold track & cold tyres on a hot track, if I am wrong I am sure some one of wiser knowlege will correct me
Chris.
Old 22-Aug-2003, 22:59   #15
Old Yella
You take your duke to Nelly's dont you ?
Mines the 748 spread all over the workshop in a thousand pieces
Old 25-Aug-2003, 20:14   #16
stewmcc stewmcc is offline
Mood: happy as a pig in sh|t
i saw that one with the buggered engine, the tyres did look quite bubbled.....
ouch on the wallet
stew
Old 25-Aug-2003, 22:25   #17
Not so much ouch!
But an end to trackdays for rest of the year
Old 02-Sep-2003, 20:21   #18
Lowside Lowside is offline
Try these for size!
LS
Old 02-Sep-2003, 20:25   #19
Donington the day after the MOTOGP - hot, hot day and SC1 front.
Old 05-Sep-2003, 16:29   #20
Monty's Avatar
Tim, I think your tyres are sh@gged.
Welll I found out what the problem was on the TZ-the rebound damping was 5, yes 5 (out of 20) clicks off the recommended setting, too dam soft.
John
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:20.
