Old 25-Nov-2005, 16:20   #11
Jasper Jasper is offline
Jasper's Avatar
EASY!!Just a circlip,washer and the Bobbin.Get them from nelly.
Old 25-Nov-2005, 16:59   #12
phil911 phil911 is offline
phil911's Avatar
Mood: Privileged ...
Basic advise :
Don't foget a drop of glue or silicon to avoid eventual bad surprises.
Original Brembo floating disks are provided with ...
Old 28-Nov-2005, 06:43   #13
loony888 loony888 is offline
Mood: sensational!!
floating rotors definitely help with heat build up, but the main reason for use is to reduce rolling resistance, the brake pads get knocked off the rotors slightly after an application of the brakes which allows the wheel to turn more freely, as well as allowing both the rotor and pad to cool more effectively.
Old 28-Nov-2005, 09:39   #14
FiscusFish's Avatar
Plus that make that really cool jingling noise when you move the bike about....
Old 28-Nov-2005, 10:14   #15
yeti yeti is offline
yeti's Avatar
Absobloodylutely
Old 28-Nov-2005, 12:09   #16
Charlie Charlie is offline
Bikes: T8 SP4 / Buell 1125CR
Charlie's Avatar
I never heard of that explanation before, for sure one of the –‘s in the extra clearance created by floating discs knocking the pistons back is not good, makes for loose feed back at the brake lever.
Old 28-Nov-2005, 12:35   #17
Thanks for the fully floating explanation guys. It seems to me that they offer a few advantages under extreme use, but I don't think I'm ever likely to need full floaters at the pace I ride at
Old 28-Nov-2005, 15:44   #18
Jasper's Avatar
Jools,you do-'cos they make that rattling sound!!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 04:48.
